It is currently Wed Aug 13, 2025 10:31 am
 Post subject: Idle Oil Pressure
PostPosted: Mon May 24, 2010 11:14 am
Just curious what oil pressure at idle should roughly be ? The engine is a mild 1275 webber and cam and done around 5000klms.....
Thanks
PG
1964 Grp Nb Cooper S
1976 911 3.6 Circuit Car
1969 911T Grp Sb Historic Racer
2009 LC200 V8 TDI.... 660nm..
2011 Golf VI, TSI
PostPosted: Mon May 24, 2010 12:12 pm
when hot... 50 is good, 25 isn't good, 0 is bad
PostPosted: Mon May 24, 2010 12:14 pm
Preferably not zero :P
With my limited knowledge I would guess not < 25psi with oil in good condition and at normal operating temp. Obviously there are factors like viscosity and how hard the engine has been working, existence of oil cooler etc.
PostPosted: Mon May 24, 2010 12:29 pm
Mods rock!
Depends a bit on oil viscosity and what the engine was built for, but at idle (~900 rpm) anything over 15 psi is OK.
PostPosted: Mon May 24, 2010 1:00 pm
New 25w50 Castrol Edge...
It appears my guage is very sensitive compaired to my race cars engine and guage......
Its moving around alot with engine revs, as expected but I didnt think it would move as it does...
Thanks
2011 Golf VI, TSI
PostPosted: Mon May 24, 2010 1:06 pm
yopu could take the relief valve out and have a look - might be some gunk in it, or badly scored
PostPosted: Mon May 24, 2010 1:17 pm
I actually replaced it and the spring I "thought" I had an oil pressure issue so replaced it as a matter of caution....
2011 Golf VI, TSI
PostPosted: Mon May 24, 2010 1:42 pm
Mods rock!
What oil pressure are you getting i) at idle and ii) when running?
PostPosted: Mon May 24, 2010 2:02 pm
Idle around 20-30, then running at say 100 kph 80psi.... obviously depends on engine rpm.....
So it appears to be OK....
2011 Golf VI, TSI
PostPosted: Mon May 24, 2010 2:24 pm
Mods rock!
Sounds fine to me, perhaps a little on the high end when running though, leads to high oil temps.
PostPosted: Mon May 24, 2010 4:43 pm
Could be worth checking the filter at the back of the gauge on both cars. See my post...
http://www.ausmini.com/forums/viewtopic ... gage+guage
Users browsing this forum: No registered users and 283 guests
