miniron wrote:
Hi Kevin,
The code was stamped on a 70 MK2 S so I think it was also a mis-stamp.
The car number matches with the ID/ADR plate but the ID plate has the correct YG2S4 code but not the radiator shroud.
Perhaps it was the same person doing the stamping and having another bad day.
I'll have to look further so see if it has the M2 06 stamped somewhere.
Regards
RonR
that is an interesting one!
if everything else checks out, I'd say you're right, just a mis-stamp. If the fella doing the stamping that day was in a hurry and had been doing matics, then the A might have been on the top of his pile...
What month in '70 is it?
there *shouldn't* be an M2 06 anywhere, just the Y*2S4 and the car number on the radiator shroud. Not all cars (mine included - July 70) had the number stamped in the channel either
my ADR plate has 'S' stamped as the seating capacity - go figure
