Idle Oil Pressure https://www.ausmini.com/forums/viewtopic.php?f=2&t=63251 |
Author: | girtp [ Mon May 24, 2010 11:14 am ] |
Post subject: | Idle Oil Pressure |
Just curious what oil pressure at idle should roughly be ? The engine is a mild 1275 webber and cam and done around 5000klms..... Thanks PG |
Author: | simon k [ Mon May 24, 2010 12:12 pm ] |
when hot... 50 is good, 25 isn't good, 0 is bad |
Author: | AEG163job [ Mon May 24, 2010 12:14 pm ] |
Preferably not zero ![]() With my limited knowledge I would guess not < 25psi with oil in good condition and at normal operating temp. Obviously there are factors like viscosity and how hard the engine has been working, existence of oil cooler etc. |
Author: | GT mowog [ Mon May 24, 2010 12:29 pm ] |
Depends a bit on oil viscosity and what the engine was built for, but at idle (~900 rpm) anything over 15 psi is OK. |
Author: | girtp [ Mon May 24, 2010 1:00 pm ] |
New 25w50 Castrol Edge... It appears my guage is very sensitive compaired to my race cars engine and guage...... Its moving around alot with engine revs, as expected but I didnt think it would move as it does... Thanks |
Author: | simon k [ Mon May 24, 2010 1:06 pm ] |
yopu could take the relief valve out and have a look - might be some gunk in it, or badly scored |
Author: | girtp [ Mon May 24, 2010 1:17 pm ] |
I actually replaced it and the spring I "thought" I had an oil pressure issue so replaced it as a matter of caution.... |
Author: | GT mowog [ Mon May 24, 2010 1:42 pm ] |
What oil pressure are you getting i) at idle and ii) when running? |
Author: | girtp [ Mon May 24, 2010 2:02 pm ] |
Idle around 20-30, then running at say 100 kph 80psi.... obviously depends on engine rpm..... So it appears to be OK.... |
Author: | GT mowog [ Mon May 24, 2010 2:24 pm ] |
girtp wrote: Idle around 20-30, then running at say 100 kph 80psi.... obviously depends on engine rpm.....
So it appears to be OK.... Sounds fine to me, perhaps a little on the high end when running though, leads to high oil temps. |
Author: | phillb [ Mon May 24, 2010 4:43 pm ] |
Could be worth checking the filter at the back of the gauge on both cars. See my post... http://www.ausmini.com/forums/viewtopic ... gage+guage |
