It is currently Thu Aug 21, 2025 8:26 pm
 Post subject: RE13 camshaft profile
PostPosted: Wed Jun 02, 2010 1:12 pm
Does anyone have the inlet & exhaaust openign & closing settings for RE13 Camshaft that I have?
I know we set the TDC of the 1st Inlet @ 108.
I would like to complete the following forumla:
Inlet Opens BTDC:
Inlet CLoses ABTC:
Duration Period: 268
Exhaust Opens BBDC:
Exhaust Closes ATDC:
Exhaust Period: 279
Cam Lift:
Value Clearance: 0.015"
I am comparing a RE13 to BMC731 profile as used in my brother-in-laws car.
Thanks
Wazza
Wazza
PostPosted: Wed Jun 02, 2010 2:20 pm
I have a BMC731 going into my engine at the moment. I was looking at the RE13, it is a better cam than the 731 i have been told, mainly because it is of much later design so its development is better than the 731 which is an old design.
PostPosted: Wed Jun 02, 2010 4:32 pm
Taken from AC Dodd's site-
"Keith Calvers (not his own I know) , RE13 Based on 1 example only;
Checking height: 0.016" @ lobe
Timing: (Intake): 34.5/61.5 (Exhaust): 63.5/32.5
Nominal lobe lift: (Intake): 0.290" (Exhaust): 0.290"
Duration (Intake): 276 (Exhaust): 276
Lobe centre angle (Intake): 103.5 (Exhaust): 105.5
Lobe separation angle: 104.5
Lift on overlap: 0.085"
Accuracy: Good"
I used to run a 731 in my 1310, it wasn't bad back then but these days it's pretty tame power-wise.
RE13 is better for torque & HP all the way up, and goes further before running out of puff.
I have one in the 1412 with Toyota Corolla 1.46:1 rockers.
It made 113lb/ft torque with a single HS6 carb, on GR's engine dyno.
Users browsing this forum: Sahig131 and 300 guests
