Mini van Q's
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63278
Author:  mokemainia [ Tue May 25, 2010 6:03 pm ]
Post subject:  Mini van Q's
Hi guys and girls...
just a few questions about a mini k van...
do i need special carpet or is it just the standard mini sedan?
also is the dash the same as the uk ones or do i need to get one made locally
cheers cam
Author:  poeee [ Tue May 25, 2010 9:36 pm ]
The carpet is the same as a sedan, except that you only need the front section (infront of the cross member).
What do you mean about the dash exactly?
Author:  Kennomini [ Tue May 25, 2010 9:42 pm ]
I f you want you can carpet the rear floor but that section is just under 100mm longer than a sedans rear floor and their is extra metal brackets in a van (for the battery and spare tyre).
The dash rails are basically the same from 1959 to 2001, just the later ones (1970) weren't designed to look nice uncovered.
Author:  watto [ Tue May 25, 2010 9:59 pm ]
Are you wanting to restore the Van to original spec, or just wanting to know what carpet fits?
Reason I ask is that Mini K Van did not come with carpet, but had the moulded plastic floor mats. Might be very difficult to find one in good condition.
Leyland Mini Van had carpet - same as sedan, but only front section.
Watto.
:shock:
Author:  bnicho [ Tue May 25, 2010 10:21 pm ]
I fitted a T**-Fit mouled carpet intended for a Mini sedan to my K van (since sold). I had to cut down the rear section to suit. I then used the offcuts to fill the area where the carpet was originally cut to fit around the rear side bins on a Mini sedan. Otherwise it was straightforward, but the fit around the tunnel was crap!
Author:  blueminivan [ Tue May 25, 2010 10:52 pm ]
I did the same with a T**-Fit in my van.
But yes, the tunnel section fitment is a little, disappointing. :roll:
Author:  drmini in aust [ Wed May 26, 2010 4:39 pm ]
I don't think the K*** auto carpets fit is any better really. I've had both. :lol:
Author:  mokemainia [ Thu May 27, 2010 4:20 pm ]
nah it wont be back to ridgey didgey..
i an just going to make it into a tidy little van to drive.
i want to cover the whole floor, inculding behind the seats, so am i better of getting a custom carpet then?
i will also have another one on the goods carrying floor too.
the dash i want to put in a timber dash with gloveboxes and what not... atm all it has is the center speedo and the shelfs....
thanks for the help
cheers cam
