dellorto firewall clearance
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63323
Author:  subwayseth [ Thu May 27, 2010 11:36 pm ]
Post subject:  dellorto firewall clearance
can anyone tell me what the distance is from the closest point between the firewall & dellorto face is. I'm using a redline 3005 manifold
thanks y'all
Author:  drmini in aust [ Fri May 28, 2010 7:24 am ]
It will clear OK, with an offset Ramflo filter- whether it's a roundy or Clubby.
However the filter case will touch the speedo cable hard on a roundy, I increased the flange angle on the manifold 3° by milling it to stop this.
Author:  subwayseth [ Sun May 30, 2010 8:03 pm ]
by touching the speedo cable hard on a roundy, do you mean if it has a cooper s/ mini k style dash cluster(which i intend on using)? is there enough room to have either a 40 or 60mm ram tubes?
