It is currently Wed Aug 20, 2025 8:55 pm
 Post subject: cylinder head gaskets
PostPosted: Tue Dec 07, 2010 9:16 pm
Hi Guys, when it comes to cylinder head gaskets is there a particular type to go for ?? I don`t want to renew the head gasket only for it to go on me later on down the track, if I use an inferior one that is. :? :? :?
Jethro
PostPosted: Tue Dec 07, 2010 9:18 pm
Some ARE better than others.
Better tell us what size motor it is, then we can all give our 2 bob's worth. :wink:
PostPosted: Tue Dec 07, 2010 9:33 pm
its a 78 Leyland mini S with a 998 motor. I have a 12G202 head to go on it.
PostPosted: Tue Dec 07, 2010 9:38 pm
ACL Monotorque. Excellent gasket. But don't believe the `monotorque' blurb, retighten it when hot, then do it again at 1000 miles or so.
PostPosted: Tue Dec 07, 2010 9:49 pm
I used a composite ACL competition head gasket. it is part number C-AEA647 or ACL AP250MT.
my engine is a 998/1098 small bore, bored to 1220.
i tensioned it to 42 ft/lb and retensioned after a hot 5 minute run. then again at 1000kms.
i am sure this would be a suitable head gasket for your 998.
see page 9 of this thread
http://www.ausmini.com/forums/viewtopic ... &start=120
you can buy these from repco, around $50 i think.
jason 8)
PostPosted: Tue Dec 07, 2010 9:56 pm
Repco $50?
You can get one from Karcraft for less than 1/2 that.. :lol:
PostPosted: Tue Dec 07, 2010 9:59 pm
ok, thanks drmini.
PostPosted: Tue Dec 07, 2010 11:10 pm
+1. The modern monotorques aren't bad. And as the doc says, they will need re-torquing at the first service when you do your tapets. The older monotorque gaskets were not really any different to the Aluminium composite gaskets (just a different material but still needed re-torquing and they were both grubby to remove..... oh and by the way, absolutely nothing wrong with the standard aluminium ones they do their job fine, its just that when you're stripping the motor they are a pain to get off).
I still use copper gaskets in my motors. I seem to be the only one, many others on here have had problems with them blowing a while ago, this could have been due to a bad batch or poor prep work (machining needs to be up to scratch if you're using copper), none of my cars were affected and none of the new gaskets I have used recently have given any issues. Many people still won't use them because they are admittedly dearer than the others (copper aint cheap). The reason I find them appealing is because they come apart clean, and if its going back on the same motor (and nothings been remachined) they're often re-useable......
Another varity are the Cometic Gaskets. They're a 3 ply stainless gasket. Very good gasket and highly re-usable (they'd want to be for how much you pay!)
Users browsing this forum: phillb and 80 guests
