carb adjustment https://www.ausmini.com/forums/viewtopic.php?f=2&t=63353 |
Author: | Dylans Clubby [ Sat May 29, 2010 2:42 pm ] |
Post subject: | carb adjustment |
I can see the nut that I need to turn, but I can't get to the thing! advice? |
Author: | DTrain [ Sat May 29, 2010 4:24 pm ] |
your not holding your tongue the right way |
Author: | afh001 [ Sat May 29, 2010 4:38 pm ] |
Do you mean the jet adjusting nut on a HS type SU? I usually use my fingers to turn it. If that fails, I have a cheap cut down 9/16" spanner thats about 2" long that does the trick. There is also a little short SU spanner that you can buy for the job. Andrew |
Author: | drmini in aust [ Sat May 29, 2010 4:57 pm ] |
If you have a Ramflo concentric filter on it (little room under for fingers) swap to an offset one. |
Author: | MG Rocket [ Sat May 29, 2010 5:39 pm ] |
If your fingers can't turn it, I have a open ender bent at nearly 90* that does it. |
Author: | Dylans Clubby [ Sat Jun 05, 2010 4:05 pm ] |
Nah it's all standard. I'll try resetting my tongue and swearing a little and see how it goes |
Author: | Convertible Mini [ Sun Jun 06, 2010 7:43 am ] |
Just rest you tongue on the exhaust manifold while you adjust the mixture.. Not. |
