| ausmini https://www.ausmini.com/forums/ |
| Cooper S VIN numbers?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=63372 |
Page 1 of 3 |
| Author: | bamnfi [ Sun May 30, 2010 6:04 pm ] |
| Post subject: | Cooper S VIN numbers?? |
I tried the search function but that wasn't much help. Is there a database for VIN numbers? |
| Author: | Morris 1100 [ Sun May 30, 2010 6:05 pm ] |
| Post subject: | |
If a Cooper S has a VIN number it must be a fake. |
| Author: | bamnfi [ Sun May 30, 2010 6:07 pm ] |
| Post subject: | |
OK, chassis number then |
| Author: | Morris 1100 [ Sun May 30, 2010 6:15 pm ] |
| Post subject: | |
How about "Car Number" because that is what BMC called it. If you want accurate figures it helps to use accurate terminology. Searching for "VIN" will get you nowhere because they don't exist. |
| Author: | phillb [ Sun May 30, 2010 6:22 pm ] |
| Post subject: | |
bamnfi wrote: OK, chassis number then
Is this the sort of thing you are after? http://www.ozcooper.com.au/build_dates.htm |
| Author: | bamnfi [ Sun May 30, 2010 6:31 pm ] |
| Post subject: | |
Morris 1100 wrote: How about "Car Number" because that is what BMC called it.
If you want accurate figures it helps to use accurate terminology. Searching for "VIN" will get you nowhere because they don't exist. OK, me a dumbass. Admit that, but it was a simple question mate. |
| Author: | Monaco [ Sun May 30, 2010 6:34 pm ] |
| Post subject: | |
bamnfi wrote: Morris 1100 wrote: How about "Car Number" because that is what BMC called it. If you want accurate figures it helps to use accurate terminology. Searching for "VIN" will get you nowhere because they don't exist. OK, me a dumbass. Admit that, but it was a simple question mate. Don't beat yourself up, I think everyone knew what you were meaning and you were not asking BMC! |
| Author: | phillb [ Sun May 30, 2010 6:56 pm ] |
| Post subject: | |
phillb wrote: bamnfi wrote: OK, chassis number then Is this the sort of thing you are after? http://www.ozcooper.com.au/build_dates.htm Actually just noticeed theres an error on that site, the prefix for Mk1 should be YKG2S2 not YG2S2 |
| Author: | Morris 1100 [ Sun May 30, 2010 7:00 pm ] |
| Post subject: | |
phillb wrote: phillb wrote: bamnfi wrote: OK, chassis number then Is this the sort of thing you are after? http://www.ozcooper.com.au/build_dates.htm Actually just noticeed theres an error on that site, the prefix for Mk1 should be YKG2S2 not YG2S2 Don't worry about the errors. Apparently everyone knows what it means. |
| Author: | mini maxx [ Sun May 30, 2010 7:02 pm ] |
| Post subject: | |
Morris 1100 wrote: Don't worry about the errors. Apparently everyone knows what it means. |
| Author: | phillb [ Sun May 30, 2010 7:08 pm ] |
| Post subject: | |
Morris 1100 wrote: phillb wrote: phillb wrote: bamnfi wrote: OK, chassis number then Is this the sort of thing you are after? http://www.ozcooper.com.au/build_dates.htm Actually just noticeed theres an error on that site, the prefix for Mk1 should be YKG2S2 not YG2S2 Don't worry about the errors. Apparently everyone knows what it means. Causing or creating vexation |
| Author: | Monaco [ Sun May 30, 2010 7:13 pm ] |
| Post subject: | |
Morris 1100 wrote: phillb wrote: phillb wrote: bamnfi wrote: OK, chassis number then Is this the sort of thing you are after? http://www.ozcooper.com.au/build_dates.htm Actually just noticeed theres an error on that site, the prefix for Mk1 should be YKG2S2 not YG2S2 Don't worry about the errors. Apparently everyone knows what it means. Nah, I would contact the person who created that site and try and make them feel insiginificant and silly over the incorrect terminology used! Then if they asked a reasonable question, I would not answer it simply because that have insulted the BMC gods! |
| Author: | simon k [ Sun May 30, 2010 7:17 pm ] |
| Post subject: | |
that'll do you lot |
| Author: | Monaco [ Sun May 30, 2010 7:18 pm ] |
| Post subject: | |
| Author: | AEG163job [ Sun May 30, 2010 10:20 pm ] |
| Post subject: | |
There's no scope for dumb-ass questions around here. Ask them and you'll get hammered. |
| Page 1 of 3 | All times are UTC + 10 hours |
| Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
