What year??
https://www.ausmini.com/forums/viewtopic.php?f=2&t=6338
Author:  Flying Brick [ Wed Apr 13, 2005 3:03 pm ]
Post subject:  What year??
How do i find out what year model my 850 is? I have no papers for it.
Steve.
Author:  mooman10_0 [ Wed Apr 13, 2005 4:51 pm ]
Look on your windscreen wiper motor, and that will give you an approximate year. Some seem to be a year out though. If not there look on the fire wall for the chrome tag, it should tell you there!
Author:  9YaTaH [ Wed Apr 13, 2005 5:17 pm ]
Post subject:  Windscreen
Some early Minis had acode on the winscreen to show the build date...
Is there no tally plate on the left side firewall... :?
Author:  68matic [ Wed Apr 13, 2005 5:29 pm ]
if not a stamped date is on the back of the speedo (if original)
some people also say the boot lock but ive yet to find this one
Author:  Morris 1100 [ Wed Apr 13, 2005 5:30 pm ]
Everything electrical has a date on it.
Generator
Starter
Wiper motor
Ignition switch
Dip switch
Light switch
Wiper switch
Regulator
Look at all the dates and guess a couple of weeks after the last date. (Unless one item is out by a couple of years!)
The paint colour is also a clue to the date. Some colours were only used in one year.
Author:  9YaTaH [ Wed Apr 13, 2005 7:06 pm ]
Post subject:  Valance
Did all 850s have the full front valance? I think so....
...there were of course Commercials fitted with 850 running gear.
Author:  drmini in aust [ Wed Apr 13, 2005 7:15 pm ]
Post subject:  Re: Valance
850s built after Deluxe came in `65, had the cutouts too. Most were badged Morris Mini Minor.. :wink:
Author:  Fruity [ Wed Apr 13, 2005 7:35 pm ]
Yep, that's how I figured out the year model of my 850. My paint colour was only used in 1962 :wink:
Author:  Flying Brick [ Thu Apr 14, 2005 7:52 am ]
Thats great thanks everyone, got a few things to check when I get home now. When you say "tally plate" does this mean the plate on the firewall with the engine number, body number and paint code on it, if so this is on there but has no date.
Thanks again.
Steve.
Author:  Anto [ Thu Apr 14, 2005 8:30 am ]
My build plate has no date - only the ADR Minis had a date on them AFAIK. I figured out that my Deluxe is a 65 because the colour was only offered in that year, and you can also check the body number against records too (at least I did for the Deluxe).
Author:  Flying Brick [ Thu Apr 14, 2005 8:54 am ]
Thanks Anto, Where can i check the records for the mini and also the paint code years.
Steve.
Author:  Anto [ Thu Apr 14, 2005 9:00 am ]
If you tell me the chassis number and engine number I may be able to give you a rough date of delivery.
http://www.ozcooper.com.au/paint_codes.htm Have a look here it may help. There's other useful stuff but it's mostly Cooper.
Anto.
Author:  Flying Brick [ Thu Apr 14, 2005 9:30 am ]
Thanks again, I had a look at the paint codes and it looks like the paint was only used up until '64, so that is something. This is what is on the plate on the firewall
Type- YKA2S1
car no.- 40715
engine no.- 8AM/U/H 615580
Steve.
Author:  Anto [ Thu Apr 14, 2005 9:44 am ]
Those numbers put it at around 12/63 date of delivery. Don't know how date of delivery compares with the actual manufactured date, but I wouldn't think they would be that different.
Don't know about the YKA2S1, 850s are YMA2S1, Coopers are YKA2S1, but then they don't have 850 motors.
Author:  Flying Brick [ Thu Apr 14, 2005 10:02 am ]
I did wonder about the engine number and car type, i saw they didn't match. I did put an earlier post on the board about that , but no luck. Thanks again for that Anto.
Steve.
