It is currently Fri Aug 22, 2025 12:02 pm
The reach to the [i]standard[/i] steering wheel of a roundie?
The wheel should be further away 20%  20%  [ 3 ]
The wheel should be closer 7%  7%  [ 1 ]
It is just right 73%  73%  [ 11 ]
Total votes : 15
 Post subject: Arm Length
PostPosted: Tue Jun 01, 2010 6:07 pm
Are you happy with the reach to the standard steering wheel on a roundy?
PostPosted: Tue Jun 01, 2010 6:16 pm
The wheel is in the right spot. They made the seats adjustable for a reason.
It should be closer for when you run a locked diff and big rubber.
PostPosted: Tue Jun 01, 2010 6:24 pm
Sure they did.. but do you set the seat so that your arms are comfortable
or your ample @ss and legs are comfortable? :roll:
PostPosted: Tue Jun 01, 2010 6:34 pm
I set it so that the arms and leg lengths are both right. It is within the range of the seat adjusters.
Just because most people don't know how to adjust their seats is not my fault.
PostPosted: Tue Jun 01, 2010 7:07 pm
Mods rock!
Most mini owners have reachers disease, so you would need to put the wheel much closer to the upper body, well away from the pockets :mrgreen:
