Starter motor
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63396
Page 1 of 2
Author:  MG Rocket [ Mon May 31, 2010 9:29 pm ]
Post subject:  Starter motor
Well it seems like my starter motor has just failed....all very sudden with
no warning. I get one loud click when I turn the key.
The battery is very good and fully charged. Checked terminal
connections and the lead to the starter.
Is there any thing else I should check, before replacing the starter?
Author:  simon k [ Mon May 31, 2010 9:43 pm ]
put a spanner across the solenoid terminals? made sure the bendix isn't stuck in the ring gear?
Author:  moemoke [ Mon May 31, 2010 9:46 pm ]
Could be just a dud solenoid, there is some way to by pass
it for testing purposes but I forget how. Or just take out the starter and
test it with jumper leads but make sure you have the starter in a vice or
put it on the floor and stand on it.
Author:  MG Rocket [ Mon May 31, 2010 9:56 pm ]
That's the funny thing....I've done that with modern cars but I don't know
where it is on this car. Is it the thing mounted next to the battery with
a starter button on it?
Author:  MG Rocket [ Mon May 31, 2010 9:59 pm ]
Or could I run a jumper lead from the + terminal directly to starter?
Author:  moemoke [ Mon May 31, 2010 9:59 pm ]
Solenoid is usually mounted on the side of the motor on the LHS eng steady bracket
Where is your battery?
Author:  MG Rocket [ Mon May 31, 2010 10:01 pm ]
Battery is on the left facing it and the thing with a starter button is directly
behind it, mounted on the inner guard.
Author:  simon k [ Mon May 31, 2010 10:12 pm ]
if there's a fat wire running from the +'ve battery terminal to that thing, then another fat wire running to the starter, then that's the one ;)
Author:  MG Rocket [ Mon May 31, 2010 10:18 pm ]
Ok, I did short that after your suggestion....a lot of sparks but no starter action. Also when I push that button only get a slight click.....so faulty solenoid?
Author:  simon k [ Mon May 31, 2010 10:22 pm ]
nah, sounds like the starter wants to come out
Author:  MG Rocket [ Mon May 31, 2010 10:33 pm ]
Thanks Simon......I'll have a look at the Gemini thread (except
I can't find it)
Author:  simon k [ Mon May 31, 2010 10:37 pm ]
you could do the jumper lead thing just to make triply sure
Author:  VulcanBB18 [ Mon May 31, 2010 10:41 pm ]
Only two bolts to drop the starter out, as previously suggested the benix might have got jammed, don't go searching out gemini starters just yet!
Author:  Convertible Mini [ Tue Jun 01, 2010 5:19 am ]
Post subject:  Gemini Starter
There are some for sale here.
http://www.miniownersclub.com.au/index. ... &Itemid=28
Author:  GT mowog [ Tue Jun 01, 2010 6:52 am ]
Maybe, but usually that is just the start of it (pun intended)......it is a sure sign that it is on the way out.....
