It is currently Sun Aug 17, 2025 6:35 am
 Post subject: Clubman S Information
PostPosted: Fri May 21, 2010 11:22 am
Hi Guys
I restored my clubman s a while back but put a 1100 in and never used the 998 engine. now my 1100 is out of order i was wondering if you guys could tell me about the clubman s 998 engine?
also it has a 1 1/5 inch su on it with a ADF needle in it which when tested on the 1100 supplied to much fuel, so i also need to know what needle to use in the carby?
PostPosted: Fri May 21, 2010 1:39 pm
Mods rock!
The ADF needle with a Red Spring is the correct one for the pollution model 998. Non-pollution motors had an ABX needle again with a Red spring.
These were on an 1 1/2" SU.
PostPosted: Fri May 21, 2010 2:24 pm
ok thats great then. i was thinking about taking the pollution system off, is there any design differences between the 998 non pollution system and 998 with, in terms of engine design?
PostPosted: Fri May 21, 2010 2:36 pm
The earlier 998s (used in Mini Deluxe and Moke) only had a 1-1/4" carby. Yours has a 1-1/2", and it's worth a couple of HP.
Otherwise not much difference- the valve sizes in the head are the same.
PostPosted: Sat Jun 05, 2010 12:49 pm
thanks guys
Users browsing this forum: No registered users and 359 guests
