Six or seven weeks ago, the statesman started to develop a persistant whistle...
Check your top right engine mount (radiator side)
Where it has the two heater pipes going into.
Drove my wife susie absolutely insane.
Take this out... theres 4 bolts with 1/2 inch nuts and heads...
Inspect for corroded metal (mine was ****** rooted, and also split the bracket bit too- that was clunking on each piece when i decelerated then accelerated again..
Took it down to the guys at the local ultratune.
Give that a shot... fixed my source in seconds.
(Edit... nar i didnt take it to ultratune... its that ****** annoying ad where he says all the "S"'s and whistles between his teeth when he says them)
