Roll Cage Material https://www.ausmini.com/forums/viewtopic.php?f=2&t=63435 |
Author: | Beanie [ Wed Jun 02, 2010 2:34 pm ] |
Post subject: | Roll Cage Material |
Hey guys Trying to track down where to buy some tube for a roll cage from .. im after some 44mm CDS tube and 38mm CDS tube but most of the normal steel suppliers dont stock ... So i wanna know where to get it ... Im in Adelaide and there are a few places that do thier own roll cages, so they are obviously getting it from a stockist .. And i wanna know who Any help would be great Thanks Beanie |
Author: | doogie [ Wed Jun 02, 2010 2:53 pm ] |
Do you have Blackwoods or One steel in Adelaide? Should be able to get it from them. Doogie |
Author: | 92 [ Wed Jun 02, 2010 10:09 pm ] |
Here you go Bean try these you will have to buy a full 6.1m length and probably a minimum of a round $150 worth http://www.atlasmetals.com.au/Adelaide.asp or http://www.vanleeuwen.com/en/worldwide.aspx?region=AUS&opco=1831 |
Author: | TK [ Thu Jun 03, 2010 8:01 am ] |
It's not made in Australia. Canadians make it. Funny how CAMS wont allow the stuff we make here be used for roll cages anymore. It was good enough for Dick Johnson when he went off in his Greens Tuf Falcon. |
Author: | Beanie [ Thu Jun 03, 2010 8:03 am ] |
Cheers Ben .. Atlas dont do the right grade of tube and dont know where to find it .. so i will give Van leeuwen a go today ... Cheers Beanie |
Author: | bnicho [ Thu Jun 03, 2010 11:35 am ] |
TK wrote: It's not made in Australia. Canadians make it.
Funny how CAMS wont allow the stuff we make here be used for roll cages anymore. It was good enough for Dick Johnson when he went off in his Greens Tuf Falcon. That's CAMS for you. ![]() |
Author: | Morris 1100 [ Thu Jun 03, 2010 6:16 pm ] |
bnicho wrote: TK wrote: It's not made in Australia. Canadians make it. Funny how CAMS wont allow the stuff we make here be used for roll cages anymore. It was good enough for Dick Johnson when he went off in his Greens Tuf Falcon. That's CAMS for you. ![]() If you had looked closely at that cage after the crash you would not use it either. It should not have failed like it did. I don't agree with much that CAMS does but I have seen a lot of aluminium roll cages fail when they shouldn't. |
Author: | Mokesta [ Thu Jun 03, 2010 6:25 pm ] |
CAMS copy the FIA who are basically French so they want a French std and that's why the (french) Canadians make it. Australian steel should be allowed IMO. M |
Author: | Number86 [ Fri Jun 04, 2010 9:12 am ] |
Beanie If all else fails, ask Walker Chassis at Houghton if you can buy some from them. You may just get stung with their mark up.... |
