how many rpm
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63446
Author:  jimmyinamini [ Wed Jun 02, 2010 6:54 pm ]
Post subject:  how many rpm
does any one know what a stock 1100 would be redlining at :?:
Author:  GT mowog [ Wed Jun 02, 2010 6:58 pm ]
With good standard valve spring, you get valve bounce about 6000 rpms.....
Author:  sgc [ Wed Jun 02, 2010 7:05 pm ]
I wouldn't take an 1100 crank beyond regularly 6,500rpm regardless.. mine never sees more than 5,500 and that's with a '295 head, double springs and electronic ignition. I like 'em reliable :lol:
Author:  Mike_Byron [ Wed Jun 02, 2010 7:11 pm ]
In a mini or a Morris 1100 ???
Many things decide the ability of a motor for its maximum revs. Its decided ultimately by the state of the individual motor's tune (I am not talking hot-up bits here), the amount of wear it has in quite a few component etc etc.
Remember the "very stock standard" formula ford kent 1600 engines could spin 8,000 rpm all day but it took $5-10K to get them that standard.
The short answer on your queston in an 1100 in a mini mostly would peak at about 5,500 rpm, some may reach 6,000 rpm. For a morris 1100 knock off a 1,000 rpm due to its sheer heavier weight.
Mike
Author:  Super-mini [ Wed Jun 02, 2010 7:19 pm ]
she'll start valve bouncing at about 5000-5500rpm
Author:  drmini in aust [ Wed Jun 02, 2010 7:28 pm ]
Properly prepped, a 1098 crank etc is OK to 7000, but not forever.
I used to rev one in my 1220 motor to 8500 back in the 60s. After 20,000 miles a circlip scored the bore. When I pulled the (was new, balanced and shotpeened) 1098 crank out, it had 8 cracks in it.. 2 per big end journal.
Soooooo, don't rev em hard, like I did. :lol:
Author:  mini-dunger [ Wed Jun 02, 2010 9:47 pm ]
my 1100 goes to 6.5
Author:  norton [ Wed Jun 02, 2010 11:02 pm ]
Mine used to see 7000 regularly and sometimes 8000
couldn't understand why the crank broke
Author:  blue_deluxe [ Wed Jun 02, 2010 11:11 pm ]
Must've been one of those weak cranks.
