Does this work?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63463
Author:  miniDave [ Thu Jun 03, 2010 4:57 pm ]
Post subject:  Does this work?
Found this product in an email from Minimania and don't know if there is something the same sold locally.
http://www.minimania.com/BulkEmail_HTML.cfm?id=1109
I still have problems with oil blowing out the breather on the tappet cover and maybe this would create a better breather - can be plumbed into a catch can sort of thing.
Author:  Phat Kat [ Thu Jun 03, 2010 5:32 pm ]
Hi miniDave..
I can't say I've used this product... How old is the motor? If you're getting enough blow by to necessitate another breather, it might be time for a rebuild. These things don't last forever after all,,,, and this product kind of looks like a patch more than a solution.
Author:  scotta_74 [ Thu Jun 03, 2010 6:49 pm ]
Dave, Give GR or the Doc a call, they should be able to point you in the right direction. Yours is only a fresh motor isn't it?
Author:  mini_mad_matt [ Thu Jun 03, 2010 6:54 pm ]
You can make one using a breather of a tappet cover or similar, braze a tube into the side of it and braze the other end of the tube onto a plate to bolt onto the block. Someone might have a pic on one. Rather common and they fit under the exhaust with the right angle on them.
Author:  drmini in aust [ Thu Jun 03, 2010 7:20 pm ]
I adapted one like that when I first built my 1310. I bolted it to the fuel pump flange and plumbed it to a PCV valve, like on a Cooper S.
All went well until the motor was run in and I went up over 4500 rpm. :cry:
Then the crank and rods threw heaps of oil into it, and the car did a fair impression of JB007's smokescreen. :lol:
Might have worked if I'd put a baffle across the entry, but I fitted a flywheel housing one instead.
I'd try that MiniMania one, it appears to be baffled internally by the way it is made.
Author:  mini_mad_matt [ Thu Jun 03, 2010 7:30 pm ]
I had the same problem when i went to lakeside. The canister had mesh in it though so i put it down to excessive blowby because the bores have corrosion marks and slopy pistons.
After the first session at lakeside when i pulled in due to smokescreening i put all the breathers into my washer bottle. After 5 laps the washer bottle was half full and oil was EVERYWHERE in my engine bay, was even coming out of the vented oil cap.
Author:  miniDave [ Thu Jun 03, 2010 9:42 pm ]
Yes - the engine is fresh, just clocked up 1,000km. The breather I have on the rear is the one that looks like a shepherd crook that bends upwards and then drains down on top of the diff.
The rocker cover is one of those shiny aluminium ones and I have doubts if it vents well enough. I like the idea of maybe putting through a hole through the rear and adapting a tube into a breather.
I have noticed when the oil level is at the top mark that comes out quicker. The level now is between the two marks and after a blast the other day there was less oil drips on the bottom of the remote.
May be it is one of those things you just live with . . . but I really hate engines that leak oil. :wink:
Author:  drmini in aust [ Thu Jun 03, 2010 9:54 pm ]
Dave, I would fit a late Clubby 998 (same as Cooper S) breather canister in place of your `shepherd's crook', and I'd run it to the vac ports on your HS2 carbs (if they have them) otherwise to a PCV valve on the manifold.
A proper PCV system maintains a slight vacuum in the crankcase, = bingo less oil leaks.
Author:  simon k [ Thu Jun 03, 2010 10:09 pm ]
it sure does.... my timing cover seal always weeped a bit of oil after my last rebuild, stopped the day after I put the PCV back on
I have 2 breathers into a sealed catch tank (90mm PVC pipe, plain cap at the bottom, screw on at the top) that is about 1.5l, and from there into the PCV. Means that if a bit of oil does get thrown out of the breathers, it won't go straight into the inlet manifold
Author:  Davo111 [ Sat Jun 05, 2010 11:52 am ]
would it be possible for a few oics of these mods, a picturs speaks a thousand words.. :wink: :wink: :roll:
Author:  Davo111 [ Sat Jun 05, 2010 11:54 am ]
Pics, Pics, Pics....sorry, little fat fingers...LOL :oops: :oops:
Author:  chazg [ Sun Jun 06, 2010 6:02 pm ]
Here is a photo a fuel pump engine breather that l have just installed on my 1380.
I haven't fitted the engine in yet. Will let you know how this breather runs later
