Tarmac Motorkhana Track-size?regulations?DYI project
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63473
Page 1 of 2
Author:  74snail [ Thu Jun 03, 2010 8:23 pm ]
Post subject:  Tarmac Motorkhana Track-size?regulations?DYI project
With a Tarmac Motorkhana Track - What size area is needed to hold an event ? What are the regulations for an event venue, noise , Council by-laws etc ? If its a CAMS affiliated event venue what would be the insurance coverage / public liability insurance ?
Why am I asking these questions ? , well , I may soon be in a position where I can build an Event Venue depending on area needed.
So any useful input/ incite is much appreciated,
anyone else who wants to fill the thread up with rubbish I will strangle you with your own intestines
Author:  simon k [ Thu Jun 03, 2010 8:34 pm ]
you need to talk to CAMS about it, asking on here won't do you any good.
The Vic mini club's CAMS representative would be the person to talk to.
The venue near here we use for Tarmac khanas through both CAMS and AASA is 50m square, and on 3 sides has a wide shallow ditch and bank to stop cars. Apparently it was earth moving engineered to stop a car properly without tipping it over etc.
like this:
/ \ _________________________ / \
\_____/ \_____/
Author:  poeee [ Thu Jun 03, 2010 8:55 pm ]
Yer I can't seem to make sense of that awesome picture there...
Author:  74snail [ Thu Jun 03, 2010 9:18 pm ]
like this:
/ \ __________________ / \
\_____/ \_____/
So by the sounds of it 200m square would be ample
Yes I realize I will need to talk to CAMS , I was interested what people who had run Tarmac Motorkhana events had to say, and any input/ incite from others who have some knowledge
thanks for that Simon, will include ditches and earth banks in the plans
Author:  simon k [ Thu Jun 03, 2010 10:00 pm ]
haha - it made sense when I was putting in all the spaces, didn't quite work...
watch this video and you can see the banks etc.
http://www.youtube.com/watch?v=wz3dRBItldA
Author:  poeee [ Thu Jun 03, 2010 10:07 pm ]
He wasn't very close to the flags. How much faster than him are you? :lol:
Author:  simon k [ Thu Jun 03, 2010 10:12 pm ]
"enough"
that was actually his second event, he's pretty good for wielding such a big car - realises that the whole drifting thing is a wank and going sideways isn't fast...
Author:  simon k [ Thu Jun 03, 2010 10:14 pm ]
200m square is a f*cking massive area - what surface do you plan to put down?
Author:  74snail [ Thu Jun 03, 2010 10:24 pm ]
Having really only just started the plans, I am looking at a good quality full-depth Hot Mix Asphalt
Author:  bnicho [ Thu Jun 03, 2010 11:06 pm ]
Sounds exciting, and unfortunately expensive...
Are you moving to the country Snail? :)
Author:  74snail [ Fri Jun 04, 2010 1:21 am ]
No I,m not moving , just making some plans within a budget, and no , not a small budget.
200m square of full-depth Hot Mix Asphalt should cost approx $13,000 if I do the site preparation , it all comes down to the bed its going on , if the soil has a higher quantity of clay then the top 10cm has to be removed and replaced with a compacted bed of fine gravel.
I want to get as much information as possible before I start sorting out possible sites, after that it will be down to local council rules and regulations- noise, environmental impact etc
As far as reasons for site development re council objections, a motorsport venue is a value added asset to boost the local economy
Author:  awdmoke [ Fri Jun 04, 2010 11:12 am ]
Good on ya!
Here's a couple of links for you:
http://www.cams.com.au/en/Media/News/2009/New-updated-Motorkhana-Test-Booklet.aspx
The Vic site: http://www.motorkhana1.webs.com/
Make sure the surface isn't swept of all the loose stones - better with a little bit of slip.
Author:  1310S [ Fri Jun 04, 2010 2:56 pm ]
200 sq meters is not big enough for a motorkhana when you consider a average house block in now about 600 sq meters, I bet you can't motorkhana on that.
Author:  drmini in aust [ Fri Jun 04, 2010 3:27 pm ]
He said 200M x 200M, (=40,000M²) not 200M²... :wink:
Author:  1018cc [ Fri Jun 04, 2010 4:07 pm ]
I can't believe you've found a supplier of AC that will supply 40,000m² for only $13,000 :shock:
That's lots cheaper than even getting a spray seal done. Who is the supplier and do they have agents in Queensland? :) :lol:
