It is currently Sat Aug 16, 2025 2:04 pm
PostPosted: Tue Jun 01, 2010 9:39 pm
so has anyone put these on a clubman? got any pics?
http://cgi.ebay.com.au/Group-2-fibreglass-arches-New-set-4-Classic-mini-/250639595495?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a5b48b7e7
PostPosted: Wed Jun 02, 2010 6:58 am
Mods rock!
You can get them on a Clubbie, but the fronts won't quite fit right up near the front, about an inch or two back from the start of the flare, there will be a gap of about 1/4 to 1/2". Also to me they don'y look right as they don't come down quite far enough at the front either (If you compare a clubbie flare to a roundy flare, the clubbie ones are a little longer).
The rears of course will fit OK.
Unfortunately, flares that fit for clubbies are slim pickin's. I haven't seen any out of the UK.
PostPosted: Wed Jun 02, 2010 12:13 pm
I've got the exact same ones on my clubman fronted van, because they use the same screw holes as the standard (exposed screw) late model uk mini flares I had.
A little bit of trimming was involved, but they feel much better quality than the plastic ones.
Pics- before:
After:
I like them. 8) :wink:
I also used the black rubber strip between the flare and the body as well as their anti kink chrome trim. I would definitely recommend both of these to be fitted when fitting these flares.
TIP: I cut the chrome strip so I had separate lengths for each of the flares and then one down the sill seam. IMO this looks heaps better than when the trim strip sits away from the flare/body on the transitions between the arches and body. :wink:
For the price I'd say go for it, especially if you have the same type of (cheap) flares I had. Also, as said, clubman specific flares are a bit harder to find.
PS: the fit is not perfect, (as you can see in that pic with the light visible) but I'm happy with how mine sit on the car. :D
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Thu Jun 03, 2010 8:03 pm
thanks guys,
just a thought clubby van...what wheels / spacers,drums ect do you have to fill out the arches?
Users browsing this forum: Bing [Bot] and 73 guests
