It is currently Wed Aug 06, 2025 2:48 am
 Post subject: carb adjustment
PostPosted: Sat May 29, 2010 2:42 pm
I can see the nut that I need to turn, but I can't get to the thing! advice?
78 Leyland Mini - Prince
PostPosted: Sat May 29, 2010 4:24 pm
your not holding your tongue the right way
PostPosted: Sat May 29, 2010 4:38 pm
Do you mean the jet adjusting nut on a HS type SU? I usually use my fingers to turn it. If that fails, I have a cheap cut down 9/16" spanner thats about 2" long that does the trick. There is also a little short SU spanner that you can buy for the job.
Andrew
PostPosted: Sat May 29, 2010 4:57 pm
If you have a Ramflo concentric filter on it (little room under for fingers) swap to an offset one.
PostPosted: Sat May 29, 2010 5:39 pm
If your fingers can't turn it, I have a open ender bent at nearly 90*
that does it.
PostPosted: Sat Jun 05, 2010 4:05 pm
Nah it's all standard. I'll try resetting my tongue and swearing a little and see how it goes
PostPosted: Sun Jun 06, 2010 7:43 am
Just rest you tongue on the exhaust manifold while you adjust the mixture.. Not.
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 64 guests
