when the wiper arms starts moving it will clear. You do not need to drill new holes for that.
Even if you put it somewhere it does not hit the arms when stationery, it will on some point when the arms start moving
Great Scott! I'd never even thought of that! Duh.
I still need to drill them though, because the holes are too small. But it will be a shame not to use the chrome dots. I rather like them.
Clutch has been assembled to the wrong height. Probably the flywheel and backplate have been refaced numerous times and the height not adjusted to compensate.
Uh... looks like a job for a real mechanic.
And another question for anyone who comes along - I'm 6 foot 4, and when I'm driving I have the seat all the way back - so I can't actually see the gauges behind the steering column. I've seen steering column lowering brackets - are these anything magic, or can I just bend a bit of metal and do it myself? How low can you go before munting the steering?
