It is currently Sun Aug 10, 2025 2:44 am
 Post subject: Air/Oil Filters
PostPosted: Fri Jun 04, 2010 10:51 pm
Hey All...
Got some more questions for you (you've all been a great help so far!)
I need to replace the air filter in my clubbie (stock 998), atm it has the stock standard paper filter (1 1/2" carby) just want to know if its worth getting a K&N Cleanable Filter and keep the stock housing? (are they worth the price hike)
http://www.minisport.com.au/prod391.htm
vs
http://www.minisport.com.au/prod1261.htm
I've also seen pancake filters and ramflo filters on the minisport website? should I be getting one of them instead? do they just replace the existing filter? or do i need some kind of adaptor?
http://www.minisport.com.au/prod378.htm
and
http://www.minisport.com.au/prod355.htm
I also need a new oil filter.... are the "HardDriver" filters worth the extra expense over the standard filters?
http://www.minisport.com.au/prod384.htm
vs
http://www.minisport.com.au/prod1272.htm
Thanks Heaps
Matt
1975 Hairy Lime/White Clubby
PostPosted: Sat Jun 05, 2010 7:56 am
Give Ash some flowers Nick .
Ok,
1) I have K&N pancake filters on my car and love them. Personally I would go a pancake filter before putting a K&N element in the stock housing. It is up to you but for a engine that is otherwise totally stock, I'd stick with the paper element.
2) Pancake filters replace the standard filter housing. Have a look at Hanra's post of his car. You can clearly see how pancake filters attach. http://www.ausmini.com/forums/viewtopic.php?t=29758. You don't need an adaptor, the mounting plate just screws directly to the mouth of the carb.
Here is a pic of my air filters: Image
3) My car has only ever used standard oil filters changed regularly (I do oil & filter changes every 1,000 miles). If buying an expensive oil filter makes you feel warm and fuzzy inside feel free to use it. I've never had any problems with my $8 oil filters. The engine in my car was last rebuilt in 1988, it spent 5 years off the road but other than that, has been an everyday driver - so it has done a few miles!
PostPosted: Sat Jun 05, 2010 9:48 am
Sounds like I should just stick with the standard gear for now
Thanks for your advice 1018
PostPosted: Sat Jun 05, 2010 10:00 pm
while I like the original look of the air filter and casing as they came out I do like the different option we have for Air Filters today . My self the 998/1098 I have ready to go into the Van will have a Ramflo on it and my wifes has a Piper X Filter. Its just a matter of getting one that mates with the stud pattern to the carb.
The 2 difference between paper and foam are. Paper is more restrictive so a foam filter will let more air in.
Paper..well it can not be cleaned where a Foam filter can
Oil Filter try your local AutoPro, Supercheap, etc...Brand, Cooper Model # WZ418 8)
