It is currently Tue Aug 05, 2025 8:08 am
 Post subject: A+ engine and remote box
PostPosted: Sun Jun 06, 2010 2:02 pm
Hey guys,
Will a remote box bolt onto a A+ engine?
and
how much power can a remote box handle (bhp)?
1971 mk2 police cooper s
1988 rover mayfair modified!!
PostPosted: Sun Jun 06, 2010 2:07 pm
Yes it will bolt straight on and no power difference between the two, as far as I know.
PostPosted: Sun Jun 06, 2010 2:11 pm
sweet,
next question is i have a reconditioned rod change box that came with the a+ engine, if i gut that will the parts fit into the remote change.
i know im doing things ass up, but its a long story.
PostPosted: Sun Jun 06, 2010 2:55 pm
Depends on the type of remote box and 998 or 1275 engine.
Power throughput really needs same answers.
PostPosted: Sun Jun 06, 2010 2:59 pm
all i know is its off a 1275 A+ engine
is there a number or something i can look for gt mowog?
PostPosted: Sun Jun 06, 2010 4:11 pm
On the front of the gearbox case behind about where the oil filter would sit there are some numbers cast on to the gearcase like 22G1128.
Just to confirm, the engine is a 1275 (12H engine no, prefix)?
PostPosted: Sun Jun 06, 2010 4:14 pm
The dropgears are different too to you'll have have the change them.
:D
PostPosted: Sun Jun 06, 2010 4:29 pm
Engine and gearbox are from an english mini
engine # 12HCO4AA
gearbox A/BZ3 DAM
BC 5626
this is what was below the oil filter
so that is true about the drop gears? wont fit in a remote box?
PostPosted: Sun Jun 06, 2010 5:20 pm
The A+ idler gear shaft is too big to fit in any A series box.
Easiest way out is find an A series 1275 primary gear, to mesh with A series drop gears.
PostPosted: Sun Jun 06, 2010 5:38 pm
engine # 12HCO4AA
gearbox A/BZ3 DAM
BC 5626
OK, but what are the numbers on the remote gearbox?
To be clear here, you wish to mate an A+ 1275 to a Remote Gearbox? (ie not Rod Shift)
PostPosted: Sun Jun 06, 2010 5:41 pm
i think i read before but ill make sure
are the gear change selectors interchangable?
PostPosted: Sun Jun 06, 2010 5:43 pm
gt mowog,
thats right, trying to mount A+ motor to remote gearbox
the remote gearbox is " mowog 22A110"
PostPosted: Sun Jun 06, 2010 6:14 pm
i'll make that last point a bit clearer
can a remote diff housing be mounted to a rod change box?
this would save me a lot of grief!!
PostPosted: Sun Jun 06, 2010 6:19 pm
No.
(That Remote gearbox case no. 22A110. Sorry, I have no listing on that, could you check it again?)
PostPosted: Sun Jun 06, 2010 6:25 pm
it should be a mk2 cooper s box
