It is currently Sat Jul 26, 2025 10:47 pm
13X8 or 13X7 wheels?
13X8 23%  23%  [ 3 ]
13X7 77%  77%  [ 10 ]
Total votes : 13
 Post subject: 13X7 or 13X8
PostPosted: Mon Jun 07, 2010 8:21 pm
Hi all,
Im looking at buying some new rims for my mini. I was looking at some 13X8 alleycat wheels. I was just wondering if there is any modifications that i would have to do when comparing to the modification to fit the 13X7 superlights? I have already cut the wheel arches but thought there might be a clearance problem with the offset and shock absorbers.
Also is there anything to be gained going to 13X8 besides a smaller turning circle and the beutiful look of a deep dished wheel?
Regards
Craig
PostPosted: Mon Jun 07, 2010 8:27 pm
Supercharged
i think 13x8 are illegal
PostPosted: Mon Jun 07, 2010 8:31 pm
Youd gain weight, track, less tyres available, heavier steering.
But itd still look pretty awesome with deep dish.
Simplify and add lightness
PostPosted: Mon Jun 07, 2010 10:12 pm
go with the 7" graig. The superlight 7" will just clear the shockers but just check the inside of the wheel arch as when the suspension is at max up-ward travel and on full lock the tyres will rub . You can fit rack limiters but then loose out on turning circle.
www.minisprintgt.com
PostPosted: Mon Jun 07, 2010 10:37 pm
when i put my 13x7s on i noticed that the 13x8s were a different off set thus having less dish?
I thought the 7s were the biggest dish you could get in a superlite/alleycat?
I think my 7s look great but they have their drawbacks...
PostPosted: Mon Jun 07, 2010 10:59 pm
where's the option for neither?
:D
tim
PostPosted: Tue Jun 08, 2010 12:23 am
Thanks for your help.
The 13X8 have a stepped dish where as the 13X7 have a flat dish.
The main concern was the scrapping of wheels on the shockers.
I think that 13X7 are the safest, cheapest and most sensible.
PostPosted: Tue Jun 08, 2010 9:10 pm
my 13x7s are crap... They are hard to hide with metro brakes. Sure they look good but because I lowered it to a normal height it now scrubs.... Pile of crap. Anyone got some 13 x 6 to swap?
blokeinamoke wrote:
