It is currently Sat Jul 19, 2025 10:33 am
 Post subject: Quaife or Salisbury?
PostPosted: Thu Jun 10, 2010 10:05 am
I am shopping for diff. Looking at LSD and wondered if anyone has some experience in this area. I am not sure which way to go, Quaife or Salisbury?
PostPosted: Thu Jun 10, 2010 10:50 am
If money is no object and it's going to be a track car then Quaiffe. The Salisbury is agricultural by comparison.
I know someone who is making up a batch of cone type diffs at the moment.
Should be a lot cheaper for a fast road-come-track car, but not as good as the Quaiffe unit.
 Post subject: Do tell!
PostPosted: Thu Jun 10, 2010 11:13 am
I did have concerns about durability with cone type LSD, however if price is right then that is certainly a consideration. Would you rate performance somewhere between the Quaife and the Salisbury then?
PostPosted: Thu Jun 10, 2010 11:54 am
The Salisbury diff is the best track diff in my opinion, it can be reconditioned and you can adjust the slip. However, the Quaife diff is more driver friendly! The Salisbury will give you big arms quickly and can be exhausting to drive.
If this is for the road, then give it a miss unless it is only for the occasional weekend fun drive. For the road, go with a cross pin diff (no driving difference other than more reliable).
The Quaife diff is easier to live with, but I would still not recommend it for everyday use.
LSD’s are hard on your steering rack, CV’s and gearbox for tight turns at low speed and remember with plate type diff’s that some oils can cause additional slip issues.
I think for the road, some careful suspension setting will address most of your slip issues without the expense and loss of driver comfort that an LSD will give you.
To answer your question regarding performance, I think it would be fair to say that the Salisbury will give better track performance, but in saying that, I should qualify it with, only with an experienced driver. I think the Quaife is better suited to an average driver simply because it is more forgiving. Quite often, I will hear people saying the Quaife diff is better and this is based on their results but, if you can master the Salisbury it will, in my view, deliver better results – both in times and muscle definition! :D
PostPosted: Thu Jun 10, 2010 12:39 pm
Where can you get a Salisbury reconditioned? I thought the clutch packs were NLA?
Member VMCI #19
 Post subject: Thanks very much!
PostPosted: Thu Jun 10, 2010 12:40 pm
Thanks for your info! You have addressed some very important issues for me to consider. As I am not looking for muscles and circuit use will be minimal with a bit of straight line action planned, I have considered your opinion and maybe I will settle for the cross pin option and drop the LSD idea all together. Thanks very much for your help!
PostPosted: Thu Jun 10, 2010 12:54 pm
Both are very good , however the Salisbury does tend to make the car go from side to side on acceleration , so bit harder to handle , also with the Salisbury you need to modify the gearbox and diff housing to fit it in there ( grind away some of the casing) ......cheers
PostPosted: Thu Jun 10, 2010 1:31 pm
I know Minisport (UK) reco them and get the clutch packs.
PostPosted: Thu Jun 10, 2010 9:35 pm
Thank-you. I didn't know they were available again
http://www.minisport.com/mini-spare-parts/info_MS3319.html
Member VMCI #19
Users browsing this forum: Google [Bot] and 110 guests
