Finally after many months..
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63652
Author:  MiniKit [ Thu Jun 10, 2010 11:38 pm ]
Post subject:  Finally after many months..
I got Hetty together enough to take her for a spin. The brakes could do with another bleed and she needs a tune up but she went. First I was off down to the servo for a nice fresh tank of premium and some air in the tyres and then off some controlled hooning around the streets. Still seems to be blowing a bit of smoke but I think it's more of a tuning problem and not heaps of oil. Do rebuilt motors smoke a bit when being run in??
No sound deadner inside the car yet, no carpet and I didn't even put on the gear lever boot or knob, she was a little noisy on the inside but all in all I'm happy.... :D
Author:  Lockie91 [ Fri Jun 11, 2010 1:31 am ]
Post subject:  Re: Finally after many months..
some do some don't. Chances are that is just the oil that was used to put the engine together, IE lubrication oil that is burning. They do tend to burn some, in the first run or two, but it is not meant to last long.
Author:  MiniKit [ Fri Jun 11, 2010 8:45 pm ]
Goodo.. I'll keep an eye on it. I admitt I did use alot of oil when I put it back together (wanted to make sure everything was well lubed)..
Author:  EAB [ Sat Jun 12, 2010 7:05 am ]
was thinking of doing this to my car as the carpet is a bit past it. how noisy is a little noisy :D bearable or not
Author:  GT mowog [ Sat Jun 12, 2010 7:16 am ]
MiniKit wrote:
..........Still seems to be blowing a bit of smoke but I think it's more of a tuning problem and not heaps of oil. Do rebuilt motors smoke a bit when being run in??
It may smoke a little when first started but should settle quickly, ie within a couple of minutes. It sounds to me like the bore could now be glazed.
Author:  MiniKit [ Sat Jun 12, 2010 10:26 am ]
not bearable. Not over any distance anyway.
Author:  MiniKit [ Sat Jun 12, 2010 10:33 am ]
Well that sucks if that's the case. It does smell a little fuely so I'm hoping towards the tuning being out as I haven't toyed with the mixture/idle or even timing yet. That's this weekends job. That and pulling the alternator to bits. :D
Author:  GT mowog [ Sat Jun 12, 2010 1:19 pm ]
Yeah, that would suck the big one. I would be happy to be wrong. :wink:
Author:  Lockie91 [ Sat Jun 12, 2010 2:17 pm ]
just take it for a very good smooth, but not hard run on the highway. Good 30min to 1hr drive on the highway, with little stopping on lights etc, and if its still there, then you have problems. Just don't let it idle and lube up etc. You'll burn anything off on the highway. :wink:
Author:  d1ck0 [ Sun Jun 13, 2010 11:44 am ]
I'm amazed at the number of people that start and run their engines for long periods of time without haveing set the timing. Driving an engine that has just been rebuilt without haveing done a tune can be asking for trouble. You can very quickly cause damage by doing so. If your timing is out it can cause all sorts of damage. Do yourself a favour and set the timing and mixtures before you go for your next drive.
Dicko
Author:  MiniKit [ Sun Jun 13, 2010 11:16 pm ]
Dicko
I had it just about right, just not spot on. It's better after today with the little bit of fiddling I did, idles smooth, no pinging, has picked up some power and ability to rev, and best of all NO SMOKE. :)
Oh and the wheels haven't fallen off either. The brakes still aren't as good as I want them to be so I'll be working on overhauling them next. There must still be air in them as I still have to pump the pedal to get it to how I think it should be. I gave them another bleed today but I didn't get anymore air out of them...
Author:  NAV [ Mon Jun 14, 2010 12:11 am ]
If the pedal is spongy the there is air in there. If you're pumping your brakes and the pedal is firm it sounds like an adjustment issue.
After each adjustment I pump the brakes and re-check and repeat until good. I've also noticed that the handbrake adjusters have an effect on the overall rear brake adjustment too. so check that as well. my handbrake is adjusted so i only can pull up 2 clicks and i have a hiogh and solid pedal.
Author:  MiniKit [ Mon Jun 14, 2010 7:00 pm ]
Thanks for the advice! Worked a treat. I have brakes, really good brakes now, they will even lock up if pressed hard enough.. On to the next problem. :D
Author:  NAV [ Mon Jun 14, 2010 8:36 pm ]
No worries. I stumbled apon the technique myself when chasing low pedal but firm brakes.
