Does GR make 100' pistons for 1098's? https://www.ausmini.com/forums/viewtopic.php?f=2&t=63674 |
Author: | mattsmadmini [ Sat Jun 12, 2010 2:44 pm ] |
Post subject: | Does GR make 100' pistons for 1098's? |
As title suggests.... i know that they are available for 998's... or is it just as easy to get a set of 998's and 'lop some off the top'? |
Author: | Wombat [ Sat Jun 12, 2010 4:52 pm ] |
Have GR's 0.100" flat tops in my 1098 ![]() |
Author: | drmini in aust [ Sat Jun 12, 2010 4:53 pm ] |
Yes he does make +.100" 1098 ones, not sure of his stock levels.. I'd be wary lopping the tops of 998 ones- .148" has to come off, so the ring land land and crown is then thin. And the bottoms MAY hit on the crank unless you relieve them. |
Author: | GR [ Sat Jun 12, 2010 6:31 pm ] |
Post subject: | Re: Does GR make 100' pistons for 1098's? |
mattsmadmini wrote: As title suggests....
i know that they are available for 998's... or is it just as easy to get a set of 998's and 'lop some off the top'? Hi Yes i have .100tho over size for the 1100, you just have to turn down the dizzy shaft to clear the piston, which i do for people that buy the 1100 pistons. Graham Russell |
Author: | mattsmadmini [ Sat Jun 12, 2010 7:29 pm ] |
Thanks guys. Graham, Will give you a call during the week ![]() -Matt |
