upper control arm https://www.ausmini.com/forums/viewtopic.php?f=2&t=63694 |
Author: | Goldbrocade_62 [ Sun Jun 13, 2010 3:01 pm ] |
Post subject: | upper control arm |
If a front subframe gets bent very obvious and the tower where the cone and the upper control arm goes looks undamaged will the upper control arm be ok. I do have others, swapping hilos cones etc to a better subframe |
Author: | GT mowog [ Sun Jun 13, 2010 3:37 pm ] |
Difficult to answer 100% correct without comparing / measuring against another, however they are very stout items and would be fairly difficult to bend. |
Author: | sgc [ Sun Jun 13, 2010 11:46 pm ] |
I'd be really surprised to see a bent top arm unless the car was a tangled mess. They're very strong.. much more so than the rear trailing arm which bend if you shout at them loud enough ![]() |
Author: | AEG163job [ Tue Jun 15, 2010 2:48 pm ] |
I agree it's unlikely the UCA is bent. But if your subby has taken a savage hit, chances are your geometry is all out of whack and alignment/tracking may be hard to get right. or to put it another way, your UCA is probably very perfectly excellent, its just in the wrong damn place! |
Author: | mickmini [ Wed Jun 16, 2010 3:41 am ] |
cheap enough to replace anyway or at least get it crack tested with die penetrant and measured against a known good one .... |
