It is currently Sat Jul 19, 2025 4:21 pm
PostPosted: Sun Jun 13, 2010 9:10 pm
I was perusing another forum and I seen this......
It would be an interesting challenge to fit carbies to it......of course the
lower holes would need plugging.
PostPosted: Sun Jun 13, 2010 9:47 pm
:shock: :shock: :shock: that would be very interesting to get running and attached..
PostPosted: Sun Jun 13, 2010 10:53 pm
That pic has been around for years... on here too. :lol:
PostPosted: Sun Jun 13, 2010 10:58 pm
If GR had one of those I bet it would go missing too.
PostPosted: Sun Jun 13, 2010 11:08 pm
PostPosted: Sun Jun 13, 2010 11:13 pm
Now you can all see why 8 and 7 port heads were made for Minis... :lol:
PostPosted: Sun Jun 13, 2010 11:19 pm
Thats quite a nice inlet angle, no steep curves or right angles. Just a nice flow.
Not as good compared to a 7/8.
Simplify and add lightness
PostPosted: Mon Jun 14, 2010 8:26 am
Ah, split Webbers :D
Dicko
PostPosted: Mon Jun 14, 2010 8:28 am
Dicko
Waste of 1 good 45 Weber these days. :lol:
PostPosted: Mon Jun 14, 2010 9:47 am
Doug Trengove did a head similar for one of his cicada clubman cars he built in the late 60's. The eng was a 1275 sprite and when he cut the head out he angled the new ports down to blend half way into th existing ports. He opened the whole port out and where it broke into the water jacket he welde a piece in to re-seal.
The new port had a spliter welded in and then shaped outwards to form a dual port. That way he ended up with 4 inlet ports with twin webers.
A lot of stuffing around but it worked well. I know he did a couple more and his son colin ran one on his mini he raced. They worked but a lot of effort to make.
www.minisprintgt.com
PostPosted: Mon Jun 14, 2010 4:03 pm
Manx (on the Isle of Man) used to do a 4 inlet port conversion (split ports) on 1275 heads, but the ports were still horizontal. Twin Webers were used.
However there wasn't room to make the ports a decent size.
PostPosted: Mon Jun 14, 2010 4:29 pm
Manx:
Looks like it has square ports?
PostPosted: Mon Jun 14, 2010 4:36 pm
The intake look like a big rectangular trumpet.
PostPosted: Mon Jun 14, 2010 5:47 pm
Manx just ground out around the push rod holes and squared it up. The ports in the head don't have spliters to separate the inlets.
When Doug did his he cut the port out into the water jacket and fitted tubes for the push rods with a full spliter plate. a lot of stuffing around ,but in the 60's he did not have 16 v/v twincams cheap and available. Ardern's were around but cost as much as you could buy a car.
Users browsing this forum: No registered users and 65 guests
