shrinking discs
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63757
Author:  Booglie [ Tue Jun 15, 2010 7:35 pm ]
Post subject:  shrinking discs
It it safe to grind an 8.4" disc down to use with 7.5" calipers? I am wanting to go back to 10" wheels but don't want to have to buy 7.5" rotors and drive flanges as cash is tight at the moment.
Author:  GT mowog [ Tue Jun 15, 2010 7:55 pm ]
It would be safe to do so, but won't work / fit with Cooper S calipers. You will need to use Cooper S Rotor and Drive Flange.
Author:  Mick [ Tue Jun 15, 2010 7:58 pm ]
I've wondered this as well. Is it the offset of the disc which means the calipers cannot be swapped?
Author:  david rosenthal [ Tue Jun 15, 2010 8:21 pm ]
Mainly the position of the caliper bolted to the hub . If you make the disc smaller then the caliper will have to be shifted in 1/2 of the overall diameter the disc was reduced or change the caliper
Author:  GT mowog [ Tue Jun 15, 2010 8:21 pm ]
No, not the offset, it's the diameter of the (bad memory) the tubualar part of the Disc Rotor. The Cooper S Calipers sit in closer to the centre of the hub.
Author:  miniobsessed [ Tue Jun 15, 2010 9:25 pm ]
The discs (8.4 vs. 7.5) sit at different 'depths'. The 7.5 disc sits much closer to the inside of the car compared to the 8.4.
I looked at doing this a while ago. I'm sure it would be possible if you put enough time into it and modified everything but at the moment you can buy a full set of new 7.5's locally for under $1000. If I had the facilities to mod everything myself I probably would but having to nut things out, take it to a machinist, try to convey what you actually want done, hope he gets it right and then pay for it it's probably not worth it...
