It is currently Fri Jul 18, 2025 9:04 pm
 Post subject: Morris 1100S & 1500
PostPosted: Thu Apr 14, 2005 6:12 pm
My knowledge of the 1100s is that its a sports edition of the 1100 and its has the A series 1275 BMC engine. But what about later Morris cars in particular the Morris 1500, does this car have an A series that will fit into a mini?
PostPosted: Thu Apr 14, 2005 6:15 pm
i think once you start looking at the bigger stock cc engine's, the weight of the engine out... er.. weighs the benefits of the cc's....
the word anchor comes to mind...
 Post subject: Re: Morris 1100S & 1500
PostPosted: Thu Apr 14, 2005 6:24 pm
Try searching ausmini first.....you will find that .....
http://www.elevenhundred.com/
has been mentioned a few times....
I ask because there seems to be alot of the Morris 1300+ cars for sale cheap lately, and alot of people looking for mini engines. Didn't think they might be too big!
PostPosted: Thu Apr 14, 2005 6:41 pm
Morris 1100 = 1098cc A-series with a 3 syncro/ 4 speed manual gearbox.
Morris 1100S = 1275cc A-series with a 3 syncro/ 4 speed manual gearbox.
Morris 1300 = 1275cc A-series with a 4 speed automatic. (no manual gearbox)
Morris 1500 = 1500cc E-series with a 4 speed manual gearbox (Optional 5 speed)
The Morris 1100 and 1100S also were available with automatic gearboxes.
PostPosted: Thu Apr 14, 2005 7:18 pm
The Morris 1300 auto (also 1100S auto) motor can be converted to fit on a manual box. Takes some machining and a custom spacer for the oil pump. PM me if you find one, and I'll convert it for you.. 8)
I'm running one now, 1360cc. Goes real hard.... :P
PostPosted: Thu Apr 14, 2005 7:22 pm
So what real difference is there in the block and crank between an 1100S and a 1300?
None I presume.
PostPosted: Thu Apr 14, 2005 7:28 pm
None I presume.
There is no difference between an 1100S Auto and a 1300.
PostPosted: Thu Apr 14, 2005 7:33 pm
A 1500 Maxi engine will fit into a mini. It is a huge lump but lines up with all the right mounting holes. Why you would do it is beyond me but choose your poison...lol
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Thu Apr 14, 2005 7:35 pm
None I presume.
Only differences in the auto blocks vs a 1100S manual are-
oil pump hole is 1/4" deeper,
no oil feed in block from pump to banjo bolt,
2 holes drilled in relief valve seat,
no dipstick hole.
On an automatic, the oil feed was external from BIG pump to the trans and its filter, then back UP the banjo pipe and into the block. :wink:
PostPosted: Thu Apr 14, 2005 9:24 pm
and dont forget the morris 1500 was OHC, someone lets go buy a Nomad :lol: :lol: :lol: :lol: :lol: read a review on one just the other
night when loking through old motor mags...they said it was an ok thing
pointless post, to many but im sure someone wouild have gained interest..
sometimes i just dont know when to jsut stop.... :lol:
PostPosted: Thu Apr 14, 2005 9:31 pm
The 1500 was a smaller version of the 1750 motor in the Marina. There was a story going around a when the cars were new and I was youg that the 1500 went as fast as the 1750 so they made the ports smaller to slow it down. BTW the 1500 was put in the Marina as well. They both made good boat anchors.
Chris
Everything I like is either
PostPosted: Thu Apr 14, 2005 9:54 pm
OTOH, the Kiwis were smarter- their Marinas got the 1275 A series. Of course now many have been plundered and their hearts shipped to Oz and elsewhere.. :lol:
 Post subject: Cables..
PostPosted: Thu Apr 14, 2005 11:20 pm
Not to mention cable operated gearbox....
PostPosted: Fri Apr 15, 2005 12:32 am
i had never seen a 1275 marina over there but have seen plenty of 1750's and have used the twin carbs off the TC model... the carb linkages were wider than the mini ones (carbs sit further appart)
