It is currently Wed Aug 06, 2025 10:28 pm
 Post subject: Master cylinders
PostPosted: Fri Jun 25, 2010 3:06 pm
Can you buy these new? Been qouted $140 ea for reco, then $50 ea for plastic tanks.
PostPosted: Fri Jun 25, 2010 3:07 pm
Yeah all the good mini places should have them.
Depending on how ruined those ones are you may want to reco them with stainless sleeves etc, would be a similar price to new ones and you can be sure they'll last.
PostPosted: Fri Jun 25, 2010 3:09 pm
been looking with no luck
PostPosted: Fri Jun 25, 2010 3:18 pm
Hmm my mistake, it seems you can get new reservoirs of that type but not the whole kits.
PostPosted: Fri Jun 25, 2010 5:42 pm
You can have them reco-d,,, you can buy the seal kits, you can buy new Plastic reservoirs & you can have the cyl body re-sleavedwith stainless steel
but you can`t buy "THOSE-PARTICULAR" clys new anymore,,, NLA
you can buy new cyls , but they come as a different shape ,,, as in, not the same "looking" or design as the ones you have
PostPosted: Fri Jun 25, 2010 7:21 pm
Matt, hows $140 ea reco'd sound. Steep or resonable?
PostPosted: Fri Jun 25, 2010 7:59 pm
Tomboss Breweros
A recon master that has been sleeved with stainless steel or hard drawn brass is better than a new cylinder IMO, so if it's the same price then it's all good.
Sleeved hydraulic parts last a lot longer than plain aluminium or cast iron :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Jun 26, 2010 7:07 pm
I pulled one apart today. Not much too em. Mine have been sitting for 20 years. Is there any way of telling visual if a re sleeve is needed. I see there are kits available for the m/c. Are they a good option and how do i tell if the kit is all that is required? I thought i'd get the new ones, but really want to keep the car looking visually original.( mk2 S ) thanks, not quite a Master of cylinders yet.
PostPosted: Sat Jun 26, 2010 7:36 pm
All the kits are is new seals and a rubber boot for the end.
They work great if the cylinder bore is good.
However, any corrosion marks (usually near the bleed port) means the fix won't last. A quick hone inside helps, but usually if corroded at all they really need resleeving.
As others said a resleeved cylinder is better than a new one for life, and will still look the same outside.
I would rather resleeve a cylinder than buy the new (wrong style for yours) ones.
