90° speedo drive angle box so I can fit RE7 manifold https://www.ausmini.com/forums/viewtopic.php?f=2&t=63816 |
Page 1 of 2 |
Author: | drmini in aust [ Fri Jun 18, 2010 9:06 pm ] |
Post subject: | 90° speedo drive angle box so I can fit RE7 manifold |
I want to fit a Russell Engineering RE7 manifold, an HS6 and Ramflo filter to my roundnose with the 1412 in it. I can get the carby to clear the body, but the filter case fouls the centre speedo cable big time. No, I am not going to run a road car with no filter... or speedo. ![]() I seem to recall a thread here that spoke of these 90° speedo drive boxes (a Land Rover part??) but cannot find it. Methinks one would solve my problem if it's not a bleedin' fortune. |
Author: | Morris 1100 [ Fri Jun 18, 2010 9:20 pm ] |
http://cgi.ebay.co.uk/Smiths-Speedo-Angle-Drive-MGB-Triumph-TR-Healey-/200475417546?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ead441bca#ht_500wt_948 |
Author: | drmini in aust [ Fri Jun 18, 2010 9:37 pm ] |
Ta for that. ![]() I think its thread may be too big, I've emailed the seller to confirm if will fit. |
Author: | Morris 1100 [ Fri Jun 18, 2010 9:40 pm ] |
drmini in aust wrote: Ta for that.
![]() I think its thread may be too big, I've emailed the seller to confirm if will fit. There is a couple of others on ebay in the UK. |
Author: | mickmini [ Fri Jun 18, 2010 10:23 pm ] |
ask Chong where he got his one from |
Author: | gafmo [ Fri Jun 18, 2010 10:25 pm ] |
Dr..don't forget I have a Mate Allen who should be able to sourse this for you also ![]() |
Author: | willy [ Fri Jun 18, 2010 10:26 pm ] |
Same as MGB. Try any B specialist you may know of. |
Author: | drmini in aust [ Fri Jun 18, 2010 10:27 pm ] |
Aha, heritage MG here we come... ![]() Around $90 on their site. Is this cheap or dear, I dunno... ![]() And is this one on the B speedo or the gearbox? Confusing... |
Author: | kiwiinwgtn [ Fri Jun 18, 2010 11:21 pm ] |
They where also fitted to Jags as standard MK2's i think, I can go have a look at my neighbours jag tomorrow, I have one in the garage i can take a pic for you when its daylight |
Author: | willy [ Fri Jun 18, 2010 11:28 pm ] |
It's the one thats mounted to the back of the speedos. It's not expensive if you need the part to get the job done. ![]() Do you have English-specific wreckers over there? Surely someone could point you in the direction of a secondhand one. |
Author: | winabbey [ Fri Jun 18, 2010 11:42 pm ] |
I picked up this Smiths right angle drive on eBay some time ago. I'm pretty sure it's the Mini speedo thread but would have to check. I won't be able to get to it for a few days. Doc - you are welcome to try it and send it back if it doesn't work out. The one's on eBay usually go for around GBP 50 (that's what I paid). ![]() |
Author: | mini053 [ Sat Jun 19, 2010 8:20 am ] |
P6 Rovers with the strip speedo also have the 90 degree fitting which I reckon will have the right threads for a Mini speedo. The gearbox driveswill be too big. |
Author: | TK [ Sat Jun 19, 2010 12:58 pm ] |
Kev, I'm running a HS6 on a Russell inlet with a Ramflow filter and it clears the speedo cable fine. Maybe it's because I machined the manifold to point the carb up a bit? I just can't get full choke operation because the jet will hit the body on full choke |
Author: | albino235 [ Sat Jun 19, 2010 2:28 pm ] |
I dono if this link will work, but minis plus have them too. http://www.minis.com.au/minis/catalog/product_info.php?cPath=30&products_id=929 |
Author: | GT mowog [ Sat Jun 19, 2010 3:55 pm ] |
albino235 wrote: I dono if this link will work, but minis plus have them too.
http://www.minis.com.au/minis/catalog/product_info.php?cPath=30&products_id=929 That one is a 1:1 ratio. Many of the angle drives are not. |
