It is currently Thu Jul 31, 2025 2:16 pm
 Post subject: Engine number
PostPosted: Fri Jun 18, 2010 11:36 pm
Hi Guys,
Just picked up an engine cheap from ebay, the engine number is 10YTah****, i've googled the model but everything comes up with 10YC or 10YJ, i believe it's a 1100 but am unsure.
Please help!!!
If it is a 1100 i can use the crank in the original 998 in my 68 deluxe as advised on an earlier post for more power for the 998.
Thanks
Al
PostPosted: Fri Jun 18, 2010 11:42 pm
1098cc... BLOCK at least :lol:
Someone could have done the dirty and put a 998 crank in.
Ok... highly unlikely.
PostPosted: Fri Jun 18, 2010 11:51 pm
try here...
http://www.elevenhundred.com/enginenum.php
PostPosted: Fri Jun 18, 2010 11:56 pm
Thanks for the info, i will strip it down and make sure its a 1100 crank!!
PostPosted: Sat Jun 19, 2010 8:15 am
...& if it is an 1100 crank (12G82) get it crack tested! Over half the ones I've had tested had to be binned because of cracks :cry:
Jacob
 Post subject: Re: Engine number
PostPosted: Sat Jun 19, 2010 1:47 pm
The Mini King
alby911 wrote:
Hi Guys,
Please help!!!
Thanks
Al
Are You sure it is not 10YaTah It is probably a 1100 cc the part number for an 1100 crank is 12G82 always check these for cracks
Users browsing this forum: Bing [Bot] and 91 guests
