Mk 1 steering column top bush
https://www.ausmini.com/forums/viewtopic.php?f=2&t=63834
Author:  ryan [ Sat Jun 19, 2010 5:14 pm ]
Post subject:  Mk 1 steering column top bush
Well, I need to replace the top bush in the steering column.
How do I remove the brass ring for the horn?
Any tips?
Can I do it in the car?
Author:  Simms [ Sat Jun 19, 2010 7:15 pm ]
Sorry, don't know.
But good to see you're not doing what I did. Thinking the ring was part of the horrible aftermarket boss on the mysterious column I had lying in the shed, I cut it off with a Dremel. Very effective method, but of course now that I know it's an essential part, difficult to refit. :roll: Turns out they're no longer available.
Maybe use a bearing puller?
Author:  GT mowog [ Sat Jun 19, 2010 7:25 pm ]
I've never had to do it on an early car, but I do note that originally they were fitted with a felt bush, so it may not come off to allow for replacement bushes of the newer type. The old felt bush wraped around.
Author:  Simms [ Sat Jun 19, 2010 7:34 pm ]
The fingers on the top end of the slip ring grab into a shallow groove in the plastic insulator underneath, but apart from it should just pull off. The fact that four of the fingers on mine were broken off even before I got to it leads me to believe it's probably a very tight fit.
Author:  ryan [ Sat Jun 19, 2010 8:03 pm ]
So.....
Do I just force it off? Won't this damage the wire for the horn?
Can it be put back on easily?
Author:  Simms [ Sat Jun 19, 2010 8:11 pm ]
No, that shouldn't damage it. The wire ends in a brass terminal on a spring, which contacts the slip ring - it's not permanently attached.
Author:  Simms [ Sat Jun 19, 2010 8:18 pm ]
I would think that it would be as easy or difficult to get it back on as it is to get it off. Probably a bit easier, since the springy finger bits won't be working against you. I can't really say for certain, since mine's in two pieces, and will be glued back on if I can't think of an alternative.
Author:  GT mowog [ Sat Jun 19, 2010 8:26 pm ]
ryan wrote:
So.....
If it jams, force it.
If it breaks, it needed replacing anyway :mrgreen:
Author:  Simms [ Sat Jun 19, 2010 8:30 pm ]
An excellent motto. :D
But in this case, it'll be difficult to replace - you can't buy the slip rings new.
Author:  ryan [ Sat Jun 19, 2010 9:49 pm ]
After posting this I went out into the garage and I actually realised that I did this same job 6 years ago and I kept the brass ring and the plastic bits, so if it breaks I have spares :) hows that for a quality memory :oops:
Author:  Simms [ Sat Jun 19, 2010 11:41 pm ]
Haha, memories aren't designed to last six years. If you get as much mileage out of one as a bar of soap you're doing well I reckon.
If nothing's busted once you've fitted your new bush and you feel like selling your spare slip ring bits, send me a PM.
Author:  ryan [ Wed Jul 07, 2010 9:09 pm ]
So, I did this yesterday. It was a very easy job. I did it with the column still in the car.
The brass ring, with a bit of twisting and a good tight grip slides off, and then I just had to fish the old bush out (this was a little tricky without removing the inner column. Then just reassembled. The new bush took up all the play. Happy Days!!!
Simms PM Sent.
