It is currently Wed Aug 13, 2025 6:07 pm
 Post subject: Exhaust Suggestions
PostPosted: Fri Jul 30, 2010 9:21 pm
Hi all
I'm in the last stages of rebuilding my engine and have come to the decision making time on what exhaust system to fit.
When I took delivery of my Mini (68 Mini-Matic), there was pretty much no remains of the old exahust system except for about 20cms of the tail pipe.
My current setup is a single carb with the standard one piece cast inlet / exhaust manifold.
I havent had the opportunity to examine other minis to see how they are setup so I am sort of new to this. Not to sound too stupid, but is there a way of using the RC40 standard setup with the single carb. Wasnt sure about the 3 into 1 extractors when dealing with the inlet manifolds.
Any help would be appreciated.
Thanks
1968 Mini-Matic ex998 Now 1098
PostPosted: Fri Jul 30, 2010 9:23 pm
Most 3 into 1 extractors (but not Maniflow) fit with a cut down standard manifold. You just cut the exhaust part off and toss it.
Otherwise, buy a Minispares alloy inlet manifold. About $100 here, less in UK.
PostPosted: Sat Jul 31, 2010 11:39 am
The minispares inlet is probably the way to go - you get the option of heating it as well. That should reduce fuel cosumption, since the fuel won't condensate on the sides of the manifold.
Unless you're running a performance engine, I wouldn't reccomend an LCB for your exhaust manifold. They're hard to install, and if you have a small block like me, they sit very low to the ground. Use a cooper freeflow manifold.
If you're running a 1275 or bigger, I don't know what to suggest, just don't use an LCB on a 998!
PostPosted: Sat Jul 31, 2010 12:07 pm
Supercharged
my ideal exhaust would be
minispares inlet manifold
3to1 extractors
inch and 3/4 pipe leading to a
twin box rc-40 setup.
PostPosted: Sat Jul 31, 2010 1:12 pm
3to1 extractors
ditto - I have an 1.75" pipe and twin box RC40 on my cooper
PostPosted: Sat Jul 31, 2010 1:58 pm
Tomboss Breweros
I have a cut intake manifold but i ported it out to suit a 1 3/4 carby and matched it to the head, they can be opened up a lot.
My exhaust is LCB's (cut open and modified for flow then welded back) then 2" down to a big baffled muffler, i like a softer deep note.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Jul 31, 2010 2:51 pm
Thanks all. Been a great help!
PostPosted: Sat Jul 31, 2010 7:07 pm
My ideal exhaust would not include anything made in England. You can get better stuff made locally from better steel.
PostPosted: Sun Aug 01, 2010 8:42 pm
i've just spent time with my exhaust man who is doing mine 3 into 1 extractors into 2'' to the rear axle then split into 2 resonators(similar looking to another mini on here QLD 11 QIK) hope he doesnt mind but it looks awesome from the rear 8)
Darren
00 triton d/cab
55 chev(oversize moneybox)
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
Users browsing this forum: No registered users and 307 guests
