It is currently Fri Aug 22, 2025 8:14 am
 Post subject: S wide arches
PostPosted: Sun Jun 20, 2010 3:53 pm
Anyone know what size rims these were used with when originally fitted?
They dwarf a 5" rim on my deluxe and even a 7" superlight only hangs out a couple of cm. Seems like anything that will fill them out is going to be over legal track width.
PostPosted: Sun Jun 20, 2010 4:23 pm
Hi PeeTee,
Can you be more specific as to the flares you are referring to?
Do you mean these?
or these?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
 Post subject: Re: S wide arches
PostPosted: Sun Jun 20, 2010 5:36 pm
Probably for 6in wide wheels, I have the original BMC wide flares fitted over 6in rims and they just cover them, but you have to remember the track is sometimes also wider with some cars (such as mine) if they have Cooper S discs, spacers or a stepped rear drum fitted.
Below is my car with 5in wide contessas fitted and then later with 6in widened Cooper S steel rims.
Only problem I find is the edge of the tyre sometimes rubs the guard if you have the wheels partially turned and you go into a dip at an angle, like leaving a servo etc.
With 5in Contessas
With 6in wide steel rims.
PostPosted: Sun Jun 20, 2010 6:30 pm
look more like UK Group 5 arches than "Cooper S" (basically Gp2) to me..
Compare the red/green cars with the blue one.
Cheers, Ian
PostPosted: Sun Jun 20, 2010 6:35 pm
you can have a 7" super light under them and still be within 2.5cm, or you can have a 6" with a beefy tyre. Get ready for the aqua plane…...
PostPosted: Mon Jun 21, 2010 5:27 am
phillb,
Those are the ones. Strangely your car is the same color as mine!
It seems odd that the arch is the right width to cover a 6" wheel but the extra width would then require the front wing to be cut back for clearance. Not possible with the riveted strip in place.
So you just grin and bear it with the occasional tyre scrub?
PostPosted: Mon Jun 21, 2010 6:21 am
PeeTee wrote:
phillb,
Yeah, I try and remember to point straight ahead if i am entering/leaving a driveway at an angle. Maybe the fact its Hydro doesn't help, and it's not like its too low either.
I'd be interested in others experiences running 10 x 6in rims.
PostPosted: Mon Jun 21, 2010 9:48 am
what's your caster like? a little bit more will push the wheels back a bit.
Although, looking at the amount of positive camber on your front wheels, I'd guess you have standard bottom arms and tie bars :D
I run a set of these which mean I can run standard ride height with a smidge of negative camber...
PostPosted: Mon Jun 21, 2010 6:57 pm
I'm after a set of the flares that are on Phillb's car and the green car. If anyone can help me out (I'm will to pay) please pm me.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Jun 21, 2010 8:12 pm
I would love a set of these as well!
PostPosted: Mon Jun 21, 2010 8:23 pm
Ryan
...and mine have a rough surface (poorly painted by a PO) and are a little cracked in places. (showing their age) Are they able to be repaired or stripped/repainted?
....or do I join the queue behind Ryan. :D
....or is there a way of copying mine?
PostPosted: Mon Jun 21, 2010 8:33 pm
I remember putting a set on a clubman, we just cut out the little lump on the front ones and glassed it up and painted it, worked fine. to copy yours they would have to be repaired, painted then a mould flopped, takes time and then the copies would still only be fibreglass not the original plastic,
not that i would care.
PostPosted: Mon Jun 21, 2010 8:52 pm
Ryan
try Simon @ British Sporting Cars in Victoria, he will make you up a fibreglass set
PostPosted: Mon Jun 21, 2010 9:02 pm
Common item from suppliers in the UK. I would be surprised if the local suspects don't carry some in stock.
Cheers, Ian
PostPosted: Tue Jun 22, 2010 7:50 am
hi 1071
If you could find me some I would be eternally greatfull. I have been looking for a couple of years now.
Phillb,
They can be repaired.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
Users browsing this forum: Bing [Bot] and 141 guests
