It is currently Fri Aug 22, 2025 6:19 pm
 Post subject: Twin SU question
PostPosted: Sun Jun 20, 2010 4:51 pm
i have a single 1.5" SU and was wondering if i found another SU just like it can you use them as a pair and build twin SU's, or can you only use a matched set. i noticed most twin SU's have the floats on opporsite sides to each other. is this correct?
just tossing some options around.
Jason
PostPosted: Sun Jun 20, 2010 5:37 pm
They really need to be a matched pair with float bowls on the outside and linkages together in the middle, like this (thanks for the eBayer who posted this pic). I'm sure I've seen unmatched twin carby setups but the linkages were a nightmare.
PostPosted: Sun Jun 20, 2010 6:03 pm
cool, thats exactly what i wanted to know. i suspected that was the case as i thought the linkages should only work if the floats are on opporsite sides.
thanks for that
jason
PostPosted: Sun Jun 20, 2010 6:18 pm
Just to confuse things, BMC did sell hot-up kits with a manifold and another carby so that you could just fit your existing carby to the new manifold (with a new needle)
This two identical carbies with the float bowls pointing the same way. It is not that hard in reality.
Some other companies offered the same type of kit.
This photo is from the 1966 Mini Deluxe accessories catalogue.
Oh, lots of other cars with multiple carbies had identical carbies in all locations instead of mirror image carbies. A Jaguar with three carbies has three the same.
PostPosted: Sun Jun 20, 2010 7:05 pm
The Sports 850 had same side bowel carbies - but they weren't supplied by BMC but by Peter Manton Motors and someone else that I sure someone else will know. These were built with BMC approval but were a private mod
David L
PostPosted: Sun Jun 20, 2010 7:08 pm
It was the same kit as the BMC one. It just had a different name on the manifold.
PostPosted: Sun Jun 20, 2010 8:46 pm
looks like i will stick with the single carb for now.
thanks for your input though guys.
PostPosted: Mon Jun 21, 2010 10:33 pm
This is my carby
It is apparently the same as a sports 850 set up.
Users browsing this forum: No registered users and 275 guests
