Rod Change Linkage Play https://www.ausmini.com/forums/viewtopic.php?f=2&t=63877 |
Author: | Hanra [ Sun Jun 20, 2010 11:16 pm ] |
Post subject: | Rod Change Linkage Play |
Uh Oh Spaghetti O.... Not sure why I never noticed this before?? Perhaps it was one of those "gunna" jobs...?? Strange that it still shifts gears fine? http://www.youtube.com/watch?v=bQ2u0sMPqXU |
Author: | AEG163job [ Mon Jun 21, 2010 9:36 am ] |
the slop doesn't look too excessive - probably quite normal. You could try a new sleeve and roll pins maybe. |
Author: | Hanra [ Mon Jun 21, 2010 9:44 am ] |
Should there be any play there at all? I would of thought it should be pretty tight? |
Author: | miniobsessed [ Mon Jun 21, 2010 6:48 pm ] |
As long as the pins are tight (not any chance of them falling out) and there is no 'rotational play' (not sure of the correct engineering term) then I can't see a huge problem with it. Over time the pins will wear into the yoke and make the change sloppy but then it'll just be like every other rod change ![]() |
Author: | KLAS [ Tue Jun 22, 2010 12:27 am ] |
quite normal, i have seen some new from the factory with more play .... |
Author: | Asphalt [ Tue Jun 22, 2010 12:38 am ] |
Yes, looks normal to me too ![]() ![]() |
Author: | Mokesta [ Tue Jun 22, 2010 8:14 pm ] |
That's WAY better than my moke! Need long arms to get first and fourth with tight seatbelt! |
Author: | Hanra [ Tue Jun 22, 2010 11:11 pm ] |
Hmmm, ok then...! I would of fitted new roll pins when i fitted it up all up. I just wouldnt of expected the shaft to have that much movement inside the sleeve and for the sleeve to have that much movement on the gearbox? |
Author: | NAV [ Wed Jun 23, 2010 1:06 pm ] |
That movement is normal. If you want to remove that play in it have another sleeve custom made up that is a tight fit over each shaft, Or have it bored out slightly and add an oil resistant rubber or nolothane sleeve inserted so its a tight fit. |
Author: | TheMiniMan [ Wed Jun 23, 2010 3:29 pm ] |
yep, all pretty normal there & in fact quite good compared to some MY advise to every one who uses rod change gearshift tho, is to use some "Tie-wire" through the roll pins as a "Just-in-case" |
