Hardie Spicer diff yoke question https://www.ausmini.com/forums/viewtopic.php?f=2&t=63914 |
Author: | guna mk1 [ Tue Jun 22, 2010 9:53 pm ] |
Post subject: | Hardie Spicer diff yoke question |
Hi all Just refitting my drive yokes to the diff and want to double check on the correct way to fit the two collets. They have a lip or ledge on one side and i assume this fits inwards towards the diff but would like to double check. Also the rubber seal that then fits on the bolt has a protruding lip on one side, does this point in to the diff or out to the washer? there doesnt seem to be a lot of room for this rubber seal to squash into? Is that normal Also couldnt find a tension to do centre bolt up to, is there one specified All replies appreciated Thanks |
Author: | drmini in aust [ Tue Jun 22, 2010 10:01 pm ] |
The chamfer on the collets goes towards the diff. The rubber seal bit goes towards the diff. But IMO these seals now are a bit too thick, they can split outwards past the washer when assembled. There is only 3.6mm of space in there for them when assembled. Note that there should be a spring washer between bolt and flat washer- if you don't use it they will definitely split. The other problem with the latest rubbers is they are just natural rubber, and the oil rots them... what were they thinking... ![]() I made 2 new flat ones for mine out of Notathane front tie bar rubbers- I sliced them off with a Stanley knife and sanded them to 4.75mm thick. Outside diameter is correct. |
Author: | GT mowog [ Wed Jun 23, 2010 7:14 am ] |
Post subject: | Re: Hardie Spicer diff yoke question |
guna mk1 wrote: Hi all
Also couldnt find a tension to do centre bolt up to, is there one specified All replies appreciated Thanks 70 ft/lbs |
