Putting hubs on https://www.ausmini.com/forums/viewtopic.php?f=2&t=63992 |
Author: | nathanm [ Sat Jun 26, 2010 1:24 pm ] |
Post subject: | Putting hubs on |
Gday just having a bit of trouble trying to get the front hub assemblies on a mini cant get it on both ball joints it is a hydro car i hope that makes sense thanks Nathan |
Author: | jester99 [ Sat Jun 26, 2010 6:48 pm ] |
Are you having trouble trying to fit the hub assembly back onto the vehicle? if so try pyring the upper control arm with a tyre lever. you can then lever the arm up high enough to get the hub in and both abll joints into place. ![]() |
Author: | grey 64 [ Sat Jun 26, 2010 6:52 pm ] |
persistance buddy. Wax on, wax off. It will go on. |
Author: | GT mowog [ Sat Jun 26, 2010 6:55 pm ] |
Being a Hydro Car, you might need to jack up the rear as well so it's not pushing down on the fronts ![]() |
Author: | GT mowog [ Sat Jun 26, 2010 6:59 pm ] |
<EDIT> Stupid ISP posted twice ^ |
Author: | drmini in aust [ Sat Jun 26, 2010 7:39 pm ] |
Once the whole side is jacked up, if you still cannot get it in, pack the upper arm up on a length of hardwood, and then lower your jack a little. |
