It is currently Thu Aug 07, 2025 3:55 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Fri Jun 18, 2010 9:06 pm
I want to fit a Russell Engineering RE7 manifold, an HS6 and Ramflo filter to my roundnose with the 1412 in it.
I can get the carby to clear the body, but the filter case fouls the centre speedo cable big time.
No, I am not going to run a road car with no filter... or speedo. :lol:
I seem to recall a thread here that spoke of these 90° speedo drive boxes (a Land Rover part??) but cannot find it.
Methinks one would solve my problem if it's not a bleedin' fortune.
Last edited by drmini in aust on Fri Jun 25, 2010 4:23 pm, edited 1 time in total.
PostPosted: Fri Jun 18, 2010 9:20 pm
http://cgi.ebay.co.uk/Smiths-Speedo-Angle-Drive-MGB-Triumph-TR-Healey-/200475417546?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ead441bca#ht_500wt_948
PostPosted: Fri Jun 18, 2010 9:37 pm
Ta for that. :P
I think its thread may be too big, I've emailed the seller to confirm if will fit.
PostPosted: Fri Jun 18, 2010 9:40 pm
Ta for that. :P
There is a couple of others on ebay in the UK.
PostPosted: Fri Jun 18, 2010 10:23 pm
ask Chong where he got his one from
PostPosted: Fri Jun 18, 2010 10:25 pm
Dr..don't forget I have a Mate Allen who should be able to sourse this for you also :wink:
PostPosted: Fri Jun 18, 2010 10:26 pm
Same as MGB. Try any B specialist you may know of.
PostPosted: Fri Jun 18, 2010 10:27 pm
Aha, heritage MG here we come... :P
Around $90 on their site. Is this cheap or dear, I dunno... :?
And is this one on the B speedo or the gearbox? Confusing...
Last edited by drmini in aust on Fri Jun 18, 2010 11:23 pm, edited 1 time in total.
PostPosted: Fri Jun 18, 2010 11:21 pm
They where also fitted to Jags as standard MK2's i think, I can go have a look at my neighbours jag tomorrow, I have one in the garage i can take a pic for you when its daylight
PostPosted: Fri Jun 18, 2010 11:28 pm
It's the one thats mounted to the back of the speedos.
It's not expensive if you need the part to get the job done. :!:
Do you have English-specific wreckers over there? Surely someone could point you in the direction of a secondhand one.
PostPosted: Fri Jun 18, 2010 11:42 pm
I picked up this Smiths right angle drive on eBay some time ago. I'm pretty sure it's the Mini speedo thread but would have to check. I won't be able to get to it for a few days.
Doc - you are welcome to try it and send it back if it doesn't work out. The one's on eBay usually go for around GBP 50 (that's what I paid).
PostPosted: Sat Jun 19, 2010 8:20 am
P6 Rovers with the strip speedo also have the 90 degree fitting which I reckon will have the right threads for a Mini speedo. The gearbox driveswill be too big.
PostPosted: Sat Jun 19, 2010 12:58 pm
Kev, I'm running a HS6 on a Russell inlet with a Ramflow filter and it clears the speedo cable fine. Maybe it's because I machined the manifold to point the carb up a bit?
I just can't get full choke operation because the jet will hit the body on full choke
PostPosted: Sat Jun 19, 2010 2:28 pm
I dono if this link will work, but minis plus have them too.
http://www.minis.com.au/minis/catalog/product_info.php?cPath=30&products_id=929
The 850 Man
PostPosted: Sat Jun 19, 2010 3:55 pm
Mods rock!
That one is a 1:1 ratio. Many of the angle drives are not.
