It is currently Sun Aug 03, 2025 2:00 pm
 Post subject: Putting hubs on
PostPosted: Sat Jun 26, 2010 1:24 pm
Gday
just having a bit of trouble trying to get the front hub assemblies on a mini
cant get it on both ball joints
it is a hydro car
i hope that makes sense
thanks
Nathan
1969 mini k
PostPosted: Sat Jun 26, 2010 6:48 pm
Are you having trouble trying to fit the hub assembly back onto the vehicle?
if so try pyring the upper control arm with a tyre lever. you can then lever the arm up high enough to get the hub in and both abll joints into place.
8)
PostPosted: Sat Jun 26, 2010 6:52 pm
persistance buddy. Wax on, wax off. It will go on.
PostPosted: Sat Jun 26, 2010 6:55 pm
Mods rock!
Being a Hydro Car, you might need to jack up the rear as well so it's not pushing down on the fronts :wink:
PostPosted: Sat Jun 26, 2010 6:59 pm
Mods rock!
<EDIT> Stupid ISP posted twice ^
PostPosted: Sat Jun 26, 2010 7:39 pm
Once the whole side is jacked up, if you still cannot get it in, pack the upper arm up on a length of hardwood, and then lower your jack a little.
