7.5" Discs https://www.ausmini.com/forums/viewtopic.php?f=2&t=64006 |
Author: | knuts2au [ Sun Jun 27, 2010 10:30 am ] |
Post subject: | 7.5" Discs |
Have a set of 7.5" discs to go on the Clubby, also have a booster (VH44?). What master cylinder do i need, will the original drum one be ok or do i need to change it. Booster or no booster? Never ran one on my old rally cars, but never got around to fitting one to see the difference. General consensus? |
Author: | TheMiniMan [ Sun Jun 27, 2010 10:39 am ] |
std master is fine,,, i don`t use boosters & nor do any of my mates now days,,, they don`t make the brakes work any better,,, it`s more a "feel" thing as the booster only relieves peddle pressure you may need to use the "S" rear brake limit valve tho,,, depending on your rear wheel cyl sizes & the condition of the rear brakes,,, if everything was std mini issue in the rear then "Usually" the rear brakes will lock up under hard braking conditions , or in the wet/dirt when "S" discs are fitted to the front |
Author: | drmini in aust [ Sun Jun 27, 2010 10:56 am ] |
TheMiniMan wrote: std master is fine,,, i don`t use boosters & nor do any of my mates now days,,, they don`t make the brakes work any better,,, it`s more a "feel" thing as the booster only relieves peddle pressure
you may need to use the "S" rear brake limit valve tho,,, depending on your rear wheel cyl sizes & the condition of the rear brakes,,, if everything was std mini issue in the rear then "Usually" the rear brakes will lock up under hard braking conditions , or in the wet/dirt when "S" discs are fitted to the front If you are tempted to keep the old rear wheel cylinders with discs fitted, I'd go try it out on a dirt road somewhere to be sure, not on the F3 at 110K in an emergency stop, like I did.. oops, plenty sideways! ![]() |
Author: | knuts2au [ Sun Jun 27, 2010 10:00 pm ] |
Just standard rear drums, can you mod the original rear valve to adjustable, the car will be seeing a lot of dirt competition. |
Author: | TheMiniMan [ Mon Jun 28, 2010 6:46 pm ] |
yes,,, but best to "try" & find a seal kit for it before you do this, but anyways---> rip it apart, drill a hole into the back of it,,, tap a thread into it,,, shorten the spring a coil or 2,,, fit the new seal kit ,,, but before setting the spring & piston assy back in it`s place, fit a one-cent piece (or flat washer of similar size) for your new adjusting bolt to work against it,,, then fit the guts back in,,, wind your new bolt in with a lock nut added to it (i usually weld a lever onto both the bolt & another lever to the lock nut so you now have 2 separate handles/levers ,,, one to unlock the lock nut & the other to adjust the bolt) then i normally fit an o-ring on in-front of the lock nut (between the lock-nut & the body of the valve) as a "Just in case" it leaks type of thing Job done & no you can start playing with your adjustment softer spring equals less pressure to the rear brakes stiffer spring means more pressure to the rear brakes |
