It is currently Fri Jul 25, 2025 10:22 pm
 Post subject: cleaning off carpet glue
PostPosted: Mon Jun 28, 2010 12:32 pm
So I just finished removing all the original carpet that was glue into my mini... how do I go about removing all the old glue? ... I want to try to remove it so I can then prime and paint over the original paint, without having to take the inside back to metal.
suggestions? can i use something like acetone ? or will that eat away at the paint as well?
Thanks
1975 Hairy Lime/White Clubby
PostPosted: Mon Jun 28, 2010 12:38 pm
3M make a great solvent remover in an aerosol can.
PostPosted: Mon Jun 28, 2010 1:05 pm
Eucalyptus oil and turpentine also turn it back into sticky gum (after a good soaking with a sopping rag)
