It is currently Sun Aug 24, 2025 4:05 am
PostPosted: Tue Jul 06, 2010 10:39 pm
Hi guys and gals
could someone please tell me what the torque settings are for the flywheel bolts, the centre hub to flywheel bolts/nuts. for a two peice flywheel.
also what the correct settings for the bolts that hold the diaphram down?
thanks in advance.
Jason :lol:
PostPosted: Tue Jul 06, 2010 11:01 pm
Set screw, driving strap to flywheel 16lb/ft
Set screw, Clutch spring housing to pressure plate 16lb/ft
Flywheel centre bolt 110 to 115 lb/ft
As per the Mini workshop manual I'm reading at the moment, but did I hear mention that there may have been a misprint in one of the books available?
PostPosted: Tue Jul 06, 2010 11:24 pm
Yeh i already have those settings. 8)
what i really wanted was the tension for the flywheel centre hub bolts/nuts?
can anyone help?
PostPosted: Wed Jul 07, 2010 7:33 am
Search is your friend -
http://www.ausmini.com/forums/viewtopic.php?t=62332
Steve
PostPosted: Wed Jul 07, 2010 1:23 pm
thanks justminis, exactly what i wanted to know. 8)
