It is currently Sun Jul 20, 2025 5:18 pm
 Post subject: Selector fork wear
PostPosted: Wed Jun 30, 2010 12:00 pm
Hi all,
I'm at the stage of figuring out which bits of my gearbox need to be replaced. The 1st/2nd selector fork has about 0.025" side clearance, and 3rd/4th has about 0.05". I assume 3rd/4th needs to be replaced, but would I be able to reuse 1st/2nd?
Harry
PostPosted: Wed Jun 30, 2010 4:17 pm
Mods rock!
They are both cactus. Maximum clearance is 0.015"
PostPosted: Wed Jun 30, 2010 5:36 pm
Ok, I'll add them to the shopping list..
One more thing, is there a trick to removing the pivot post that the bellcrank levers sit on? I'd like to renew the seal there, but I haven't been able to drift the post from the case (which is what the manual suggests).
Harry
PostPosted: Wed Jun 30, 2010 6:00 pm
Mods rock!
Harry
These don't normally give trouble so I usually leave them, but if you have disturbed it best to keep going with it. I have a support that I put under the gearcase that is a lttle larger in diameter than the pivot boss (underside) and I press them out. The gearcases are only alloy so I feel it not a good idea to go banging stuff around in them.
PostPosted: Wed Jun 30, 2010 7:02 pm
They had .015" clearance when NEW, I'd say a bit more is OK. IMO if over .030", find new or better ones. Yes we know they are expensive now.:wink:
[edit] The Poms being cheapskates often squeeze them in a vice to close them up, I don't like to do this as they are a casting (brittle).
PostPosted: Wed Jun 30, 2010 7:10 pm
Mods rock!
Sorry here but I beg to differ, I have found them NEW to be around the 0.005 - 0.006"........but then that is on a Rod Shift :wink:
Oh and I only use genuine ones............
Sorry here but I beg to differ, I have found them NEw to be around the 0.005 - 0.006"........
Well I did find that figure in a BMC factory book somewhere. :lol:
PostPosted: Wed Jun 30, 2010 7:13 pm
Mods rock!
Page f6 of the Black Book :wink:
PostPosted: Wed Jun 30, 2010 7:17 pm
I successfully built a pair or remote forks up 15 years ago with SBA245 silver solder, and machined them to fit.
I rebuilt the GT box (ex Chris Buckingham) for my boss along with the motor (now 1330) but it's still sitting on a pallet at work!!:mrgreen:
I'm sure they will work OK, silver has a low friction coefficient and this stuff won't melt until 610°C.
PostPosted: Wed Jun 30, 2010 7:23 pm
Mods rock!
I've often looked at doing something similar, especally on 1st / 2nd fork. The thrust area on these is pittiful. No wonder they wear so quick.
Users browsing this forum: No registered users and 68 guests
