1620cc is available if you wanted,,,, but it`s a bit "If-y" in a number of departments
My dad sorted something around a 1700cc "Thing' for a speedway fella up north,,, not exactly sure of the actual capacity cause i was just a little kid back then,,, but around 1700cc,,, offset bored, then sleeved then offset bored again etc,,, add BIG stroke crank (welded up & re-machined)) & all the associated oil plumbing & clearance problems etc etc etc
I never went for a fang in it but dad said it was "THE" torque monster
& yes , as the good doc says,,, the HP on Massive mini engines "Usually" isn`t that fabulous for the sake of all the pumping losses & frictional losses & all the other associated losses,,, BUT THE TORQUE
YEE-HAA !!!!!!!!!!!
Stewys Sports sedan is 1600 (1591cc to be precise) & it is also a MASSIVE TORQUE MONSTER,,, still revs quite hard,,, but short shift it & "WHOA""....---> hang on tight
Not sure many people in the world have had the opportunity to go for a drive in a mini engine this big but i can assure you it really is fabulous to drive,,,, if you accidentally slip it into 6th gear when going for 4th,,,, well it doesn`t care,,, it doesn`t seem to worry or even notice it
& if you can fathom that sort of torque then you may have some sort of idea,,, but until you drive something this size,,, well you just don`t have a clue
My roady is 1510cc & is lovely & drivable,,, mlld cam & mild compression thing, keeps it very sedate & very calm,,, leave it in top gear & do whatever you want with it,,, most people don`t even believe that it`s so big when i take them for a sedate, smooth calm comfortable drive down to the shops,,, but on the way back i give it some & then they go--> FFFFAAARRRKKKK!!!!,,,
... click it back a couple of gears & rev it to 7800 every gear (inc top gear) with the 3.2 F/D ratio,,, it`s happy either way
You can all do the sums to work out what a 3.2 diff & 7800rpms gives top speed
BUT!!!!!!!!!!!!!!!!!!! I`m working on this project,,, it`s a bit of a secret at the moment so don`t tell anyone,,, "IF" it works then we are talking (up-to) 1750ccs-ish & multi-valve,,, & i mean "MULTI"
The Bimmer Twinky had to be done, but this thing is (or rather "may be") on a whole `nother level again
Expensive tho
... don`t think i`ll be making "Kits" for it like i have the Bimmer... Just simply "WAY-TOO" much for the average Joe-Jane Doe to comprehend , let-alone fork out the quantity of money needed to complete it
But still... the average Joe-Jane Doe is "Usually" quite happy with a 1380 or 1415 or even the odd 1430-1450 etc,,, nothing wrong with them as road engines if the cam & comp ratio is kept fairly realistic for pump fuel,,, dam good Roadys in my books
My suggestion to everyone who is after a VERY RELIABLE BIG mini engine for road use,,, is 1360cc,,, & add a stroker crank if you want that bit more,,, those 2 design engines are just fabulous , un-breako,,, wonderfull power units,,, just can`t go past them in the "Bang-for-buck" ratio really (IMO)
