It is currently Mon Jun 30, 2025 1:01 am
 Post subject: oil pressure help
PostPosted: Sat Apr 16, 2005 5:46 pm
okay just changed the oil
before the pressure was 40 at idle and 60 while driving
its not 60 at idle and 80 while driving?
can anyone tell me if its good or bad or what/ i have no idea and im panicing
PostPosted: Sat Apr 16, 2005 5:51 pm
did you change type of oil?? 20w50 to 10w20 maybe??
1974 Moke - 998cc
 Post subject: .
PostPosted: Sat Apr 16, 2005 5:53 pm
not sure?
so its it okay?
PostPosted: Sat Apr 16, 2005 5:59 pm
Relax - an oil change is a good thing - more oil pressure is a good thing - I'll let the experts explain. :lol:
PostPosted: Sun Apr 17, 2005 2:38 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
man i wish my oil pressure was that good
nothing to worrie about aslong as it dont go to high like over 100psi then ya got's a blockage but all is fine it is just with the new oil it has a better viscosity (thicker) and will keep everything were it needs to be
makka
PostPosted: Sun Apr 17, 2005 7:09 am
I just rebuilt the 1360, oil pump is a new MiniSpares Sureflow..
With cheapo 20W/50 Valvoline SF oil for run in-
80psi cold,
75psi hot,
60-70psi idle hot.
Note it has a 9/16" ball relief valve, this keeps the idle pressure up as it can actually seal, unlike the POS standard valve. :wink:
And this is without the oil cooler.. I'll refit it before track days though. 8)
 Post subject: Re: .
PostPosted: Sun Apr 17, 2005 10:01 am
djstib wrote:
not sure?
so its it okay?
that's a bit of a worry in itself :shock: :lol:
Lillee - 1969 Morris Mini K
