It is currently Sat Aug 02, 2025 7:29 pm
 Post subject: dwell angle
PostPosted: Sun Jul 04, 2010 8:00 pm
Is the correct procedure to check dwell angle to connect the two leads to the coil, disable the distributor and check the dwell reading whilst turning the motor over on the starter?
PostPosted: Sun Jul 04, 2010 10:42 pm
sounds pretty good to me .. Why you asking
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Mon Jul 05, 2010 1:27 pm
I'm not sure if this is the correct procedure, or do you check it with the engine running, obviously get two different readings, wondering which is correct.
PostPosted: Mon Jul 05, 2010 1:32 pm
Whether it is right or not but I have always done it with the engine running, noted the reading, popped the cap off made a bit of an adjustment and re-checked the reading. Never had any issues doing it that way.
PostPosted: Mon Jul 05, 2010 2:52 pm
How it's connected depends on it's design. Some work across the points and others across the coil. You really need to follow the dwell meter's instructions.
